i have access to a 14 bolt
Old Aug 12, 2009 | 12:03 AM
bubbakutz's Avatar
Default i have access to a 14 bolt
so my buddy bought an 84 gmc k2500 and it has the 8 lug 14 bolt semi floater 9.5" in it. he said he would give it to me. any good? i know most of you guys are running the 88-98 rears. i don't know much about the swaps into the nbs trucks. i just know my perches are going to have to be moved out. what about the axle width compared to mine?
i want to convert it to 6 lug and disc brakes. i already have disc's on my truck btw. leaning towards using my stock 10 bolt disc setup but still trying to figure out a spacer. i saw one thread on here where a guy made a set. https://www.performancetrucks.net/fo...d.php?t=402503
i can just get 6 lug axle shafts for a 14bsf and they will go in no problem right?
any advise would be great.
Old Aug 12, 2009 | 12:07 AM
00ChevyScott's Avatar
Wearin' da big hat
What are your future plans for the truck.
If you plan on running tires 35" and smaller and light offroading, or anything under 700 rwhp, you will be fine with the 10 bolt.
Old Aug 12, 2009 | 12:09 AM
Atomic's Avatar
I have a gauge for that
Get it and switch out the shafts for 6 lug shafts and you will be good. Spring perches need to be moved in 2". WMS to WMS is roughly the same for both, maybe 1" shorter for the OBS.
Im having issues with my 10b rotors fitting over the 14b flange, but I may have a solution tomorrow. I have been driving it as is for 3 months if that says anything though...
Old Aug 12, 2009 | 12:13 AM
bubbakutz's Avatar
i don't trust my 10 bolt. i already blew the **** out of the spider gears. this will be a slow build until my 10 bolt goes. i have no idea where my truck will go from here. it's always changing lol.
where does everyone get shafts. i just want stock ones. don't need superior or anything like that.
Old Aug 12, 2009 | 12:22 AM
Wearin' da big hat
I've broken my spider gears 3 times. Then I spent the money on a truetrac and haven't had ANY problems since.
Old Aug 18, 2009 | 11:27 PM
bubbakutz's Avatar
gonna bump this back up. who here has done the conversion? curious as to your brake setups.
Old Aug 19, 2009 | 12:03 AM
Atomic's Avatar
10b to 14b? I have. Used the 10b rotors, calipers, and backing plates spaced correctly to fit the 14b. After I ground the flanges on the 14b shafts slightly the rotors fit perfect and work like stock.
Old Aug 19, 2009 | 12:55 AM
bubbakutz's Avatar
what did you use for spacers for the 10 bolt backing plate? any pics?
Old Aug 19, 2009 | 07:21 AM
Atomic's Avatar
grade 8 nuts
https://www.performancetrucks.net/fo...d.php?t=441553
natejk
Nov 15, 2016 08:05 AM
mikeyjm1
17
Oct 29, 2015 11:04 PM
Justin87gn
Sep 10, 2015 12:06 PM
iregret
Sep 7, 2015 01:20 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
