New inline fuel system
Old May 16, 2012 | 04:52 PM
  #31
Atomic's Avatar
I have a gauge for that
One type is meant for inline use, the other for intank use.
Old May 16, 2012 | 05:07 PM
  #32
Superado's Avatar
11 Second Truck Club
Correct.
044 = inline (threaded inlet /outlet)
040 = in-tank (screened/open inlet, threaded outlet)
Old May 21, 2012 | 08:39 AM
  #33
Superado's Avatar
Well...a few additions to the fuel delivery system are in the works:
1. FAST fuel rails (and LSXRT intake)
2. FAST crossover
3. all the necessary AN fittings and hose
4. Magnafuel MP9925-B fuel pressure regulator
Old May 21, 2012 | 08:52 AM
  #34
Kemble's Avatar
When does the return line start to pose a problem with fuel backing up? Also is the goodyear hose legal at your racetracks?
Old May 21, 2012 | 09:02 AM
  #35
Superado's Avatar
Haven't read of anyone having that issue.
HAVE read of several 1000+ HP set-ups running both stock feed and stock return lines though.
Not sure on the hose.
It won't be an issue at the two tracks I frequent.
Old May 21, 2012 | 09:12 AM
  #36
Atomic's Avatar
You can tell the return line is too small if you cant hold a lower pressure at idle.
Old May 21, 2012 | 09:14 AM
  #37
Superado's Avatar
Thanks...I'll keep that in mind and run a larger return line if I see that is the case.
Old May 22, 2012 | 08:21 AM
  #38
Superado's Avatar
Originally Posted by LS1FREEK
If you don't mind me asking, where did you get the pumps for $98??
Originally Posted by Superado
It says Bosch 044 Type, and also cross reference number 0 580 254 044
What brand are they?
As far as I can tell they are Bosch.
I saw the term "type" used quite often in the description of the 040 and 044 pumps all over the internet.
The hardware pack that ships with them is identical to the Bosch.
I compared these pumps to the Bosch I already had and other than "Bosch" and a series of #'s being printed on the pump itself...they are identical.
The guy selling them had good ratings on several forums...just been a while.
His e-bay rating is high as well.
Just so everyone knows...
I just found out that these pumps are NOT Bosch pumps...which doesn't surprise me considering the price.
We'll see how well they do.
Replies from seller:
I have been selling them for a little while and haven't had any issues. I ran two on my old twin turbo ls1 powered truck.. Had no problem making a little over 800hp to the wheels.
These are aftermarket pumps, although they are built completely to Bosch specifications. Materials are the same, flow characteristics, etc. I have sold many of these pumps and never had any complaints or returns. Let me know how they work on your application! Thanks!
He was on LS1TECH and several other forums as well that I found...member name, 1SICKWS6.
Has a trader rating of 38 here...w/ 100% positive feedback.
His ebay rating (rcconcepts) is 100% positive w/ a feedback score of 1257.
Old May 22, 2012 | 07:36 PM
  #39
AndysC3's Avatar
Keep us updated on how the pumps perform. They might be a cheaper alternative to the Bosch pumps.
Old May 22, 2012 | 08:56 PM
  #40
Superado's Avatar
Will do.
