turbo oil return, what kind of pump???
Old Jan 25, 2009 | 09:28 PM
PappyDan's Avatar
Tribe Shaman
Default turbo oil return, what kind of pump???
if i was to put a turbo system on under my truck, what kind of a pump
would i need to send the oil back to the block?
Old Jan 25, 2009 | 10:24 PM
Coban's Avatar
Good thread.
https://www.performancetrucks.net/fo...ght=sts+return
Old Jan 25, 2009 | 11:44 PM
BlownChevy's Avatar
blownerator
25 Year Member
Just to a top/front mount and be done with it. Do not trust or rely on those pumps to be there when you want them to.
Old Jan 26, 2009 | 12:49 AM
PappyDan's Avatar
Tribe Shaman
that means new headders, new exhaust.
i can save myself a **** load by having a twin turbo system in the rear like the sts vett set up.
all i have to do is cut the pipes, weld on the flanges, and run the air up to the intercooler.
all i need is a way to send the oil back up to the motor.
Old Jan 26, 2009 | 01:46 AM
silver-mod-o's Avatar
Hunt&Fisherator
There's gotta be a better pump out there than what comes with the STS.... I'd drop serious coin on a pump if it gave better piece of mind about an expensive engine getting toasted....
But I'm front mounted my turbo oil pump is on the end of the crankshaft
Old Jan 26, 2009 | 02:08 AM
PappyDan's Avatar
Tribe Shaman
it would'nt be such a problem if i had a way to cool the oil.
then i could use a cheap fuel pump to send the warm oil back to the motor.
Old Jan 26, 2009 | 02:45 AM
RandomHero's Avatar
The Pump was the exact reason why I sold my STS kit. I just don't feel comfortable with it.
Old Jan 26, 2009 | 02:53 AM
Hunt&Fisherator
Why couldn't you run it through some type of h/x.... Just monitor the temps after the cooler and see if they're low enough to be pumped with a fuel pump...
Old Jan 26, 2009 | 03:06 AM
PappyDan's Avatar
Tribe Shaman
im game i'll give it a try, i'll pick up an B&M supercooler and see how much it lower the temp on my motor oil.
if i can get to drop low enough so it wont harm the plastic parts inside.
Old Jan 26, 2009 | 11:04 AM
kbracing96's Avatar
http://www.enginegearonline.com/gepu12or24vo.html
Same pump STS uses, and it's a quality pump. Brass gears, SS shaft... I ran 1 for 2 years and to my knowledge its still running on the old setup. They're pricey now, they were about $100 cheaper a year ago.
