turbo oil return, what kind of pump???
#51
I was never given the build sheet although I asked for it on 2 occasions. I understand everybody has too much on their plate usually. I'll try to find out.
#52
All of the harnesses the STS has produced shared this one simularity so the system you worked on might have had a harness built by the installer. There is really no way to hook it up wrong either as the fused lead is a constant power and the blue wire is a trigger to both power the oil pump relay and the oil alarm buzzer.
#53
IIRC, the wire that gets hooked to the battery has an in-line fuse. This is the ONLY wire that connects to the the + side of the battery. Therefore if the fuse goes, you lose power to your whole system. To say a fused lead is a constant power is misleading.
I remember the fuel pump wire being tapped, but I doubt that powers the oil pump since you don't want to run two pumps on one fuse and relay.
#54
#55
I've been wondering if it would be a bad idea to use something like a dry-sump oil pump to suck oil from the turbo? They are capable of pulling a pretty strong vacuum. It would only work when the engine is on and even at idle they have the ability to pull a strong vacuum. You wouldn't have to worry about any wiring issues whatsoever. They aren't cheap, but neither is a good electric oil pump, the wiring, warning buzzers and lights, etc. They are very dependable also. There are kits for mounting dry-sump pumps on LSx engines, but they may need to be modified for a truck.
GMCtrk
Jul 17, 2015 06:39 PM
