turbo oil return, what kind of pump???
i can save myself a **** load by having a twin turbo system in the rear like the sts vett set up.
all i have to do is cut the pipes, weld on the flanges, and run the air up to the intercooler.
all i need is a way to send the oil back up to the motor.
There's gotta be a better pump out there than what comes with the STS.... I'd drop serious coin on a pump if it gave better piece of mind about an expensive engine getting toasted....
But I'm front mounted
my turbo oil pump is on the end of the crankshaft
im game i'll give it a try, i'll pick up an B&M supercooler and see how much it lower the temp on my motor oil.
if i can get to drop low enough so it wont harm the plastic parts inside.
http://www.enginegearonline.com/gepu12or24vo.html
Same pump STS uses, and it's a quality pump. Brass gears, SS shaft... I ran 1 for 2 years and to my knowledge its still running on the old setup. They're pricey now, they were about $100 cheaper a year ago.
