Talk about prochargers
Old Feb 16, 2015 | 03:43 PM
  #101
E.A.'s Avatar
Originally Posted by turboal1
thinking about putting a P/C on my 5.3 Colly, need a passenger
side mount. nothing killer 8-12 psi.tops. how about some suggestions.
I will need to use a Silverado setup, they don't make a Colly setup.
it's going to be a tight fit, there's not a lot of room to work with.
truck specs in sig. eng is a LH9 w/799 heads
You should be able to run the HoB dedicated drive on the passenger side.
Trailblazer SS ProCharger Supercharger Bracket-Only System - House of Boost :: We Make Fast Stuff FasterŽ - (Powered by CubeCart)
I ran this bracket on my 2008 5.3L truck, with my own China intercooler, and tubing.
Bolted right on, no drama. And TBSS guys have been using it up to over 1000rwhp, and big F-1R's.
Another guy runs it on his 5.3L swapped blazer with modifications to lower the main bracket down a little bit. If hood clearance is an issue, that might be the solution.
Old Feb 16, 2015 | 07:45 PM
  #102
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
brace I've been making to do away with the main bracket flexing should work pretty good had it mounted up last night theres zero flex now
when i get it all painted up and mounted for good ill take some better pictures
Old Feb 17, 2015 | 11:51 AM
  #103
turboal1's Avatar
Default Pro Charger setup
Thanks E.A. do you know the post/guy who has the Blazer ?
Old Feb 20, 2015 | 03:24 AM
  #104
Blown06's Avatar
8 Second Truck Club
There was a discussion over on the bullet and someone asked me what my secret was for almost never having belt issues with the procharger stuff. I felt like my response was well served over here as well. This is what I wrote:
There is no secret.......just attention to detail.
Perfect pulley alignment, belt tension, bracket rigidity and BOV capacity. 99% of the people complaining about belt issues when running a procharger, don't spend the effort to perfect those four things.
I post on performancetrucks.net daily and have been on that site since 2006. It's very much a street oriented site so almost any supercharged combo talked about over there is going to be a serpentine belt. Prochargers have a very bad reputation on that site and just about every guy that has tried the procharger route eventually ends up going turbo b/c they have belt issues. It is almost exclusively blamed on the procharger kit as no one ever personally takes the blame for having belt issues, when 99% of the time is the users fault, not the kit.
Old Feb 20, 2015 | 09:54 AM
  #105
black00chev's Avatar
Slowest turbo build ever!
If everyone just used the damn cog kit there would never be belt issues!!!
Old Feb 20, 2015 | 10:15 AM
  #106
turboal1's Avatar
Default P/C brackets
checked out HoB site, the brackets are awesome, but i almost
choked on the price. $1550.00 bucks. they work with
almost all the head Pro Charger head units. so it looks like i could
put my own kit together
Attached Thumbnails Talk about prochargers-hob_tbss_stageii.270.jpg   Talk about prochargers-hob_tbss_8rib.600.jpg
Old Feb 20, 2015 | 10:22 AM
  #107
thewrx's Avatar
I had a D1 on a tbss, not sure if I posted earlier.
Old Feb 20, 2015 | 10:28 AM
  #108
blown02408's Avatar
02 w/ lowest mileage 2800
Not true, even some guys with cog drives can't figure out why their belt keeps walking off. It's usually the result of too much tension, cog belts shrink when they heat up pulling the blower forward causing them to walk off.
I agree with Blown06, 99% of people don't address the real problem before jumping ship.
Old Feb 20, 2015 | 06:23 PM
  #109
I'm pretty sure i figured mine out like stated i needed to address the belt issues once thats solved your good to go
i have no plans on ditching my procharger my next setup will be a F1
Old Feb 21, 2015 | 01:41 AM
  #110
Blown06's Avatar
8 Second Truck Club
I don't think that it is so much the belt shrinking as it is the motor expanding.
