Idler Pulley question
Old Feb 28, 2011 | 06:35 PM
TIM Z's Avatar
11 sec. Truck Mod
Default Idler Pulley question
I am looking to upgrade my idler pulley that came with my blower kit.
I currently have an idler pulley that measures 3'' OD / 76.1mm,
To get my HD tensioner in the middle of its travel, i need to get a 1/2'' shorter belt,
So instead of buying a shorter belt i thought of getting a larger idler pulley.
To gain 1/2'' i would need a 90mm idler pulley.
Where do you guys suggest buying one and is there one better than another to get ???
Or should i get a 100mm and then buy a new belt???
Belt wrap is damn good as is on my blower pulley,
Thanks for the help!
Old Feb 28, 2011 | 07:16 PM
04SilverCrew's Avatar
I would go with a new pulley... its prolly cheaper than a new belt. Unless you are replacing the idler that is part of your s/c kit. Then a belt might be cheaper. Do you have an idler thats factory to the truck that you could change? Those dayco idlers are pretty cheap. Keep in mind too... if you are liike me and keep a spare in the truck, then you would need a new spare belt as well.
Old Feb 28, 2011 | 07:46 PM
03sierraslt's Avatar
I would like to find a bigger idler for mine too Tim. I am staying tuned.
Old Feb 28, 2011 | 07:48 PM
terravast4's Avatar
just get the 100mm pulley and enjoy more tension
Old Feb 28, 2011 | 07:50 PM
Here ya go
https://www.performancetrucks.net/fo...ht=Dayco+Idler
Old Feb 28, 2011 | 08:04 PM
TIM Z's Avatar
11 sec. Truck Mod
Thanx Pat,
I was actually looking for that thread, Search didnt turn it up, This damn site is slow again tonight, and im getting database errors
Anyway Are the Daycos good pullies?
Old Feb 28, 2011 | 08:11 PM
Originally Posted by TIM Z
Thanx Pat,
Thats funny I found it with the search function..... Dumbass....
haha. I believe they are the same as stock but i am not sure. That link has Part#'s for the Gates pullies. I found both the 90mm and 100mm on amazon. I am not sure what I already have on mine so I need to check then take some measurements to decide if I am going to go with larger ones or not.
Old Feb 28, 2011 | 09:29 PM
1Bear's Avatar
While I personally use the Gates 100mm piece, the Dayco equivalent is 89055.
Old Mar 1, 2011 | 04:42 AM
TIM Z's Avatar
11 sec. Truck Mod
Wow thanks.
Thanks 1Bear, i was hoping you would post.
Old Mar 1, 2011 | 05:19 AM
Wow thanks.
Whoaaa easy on the man love.
thunder550
Oct 8, 2015 04:53 PM
wrb002
Aug 25, 2015 03:56 PM
USMCvet0311
Aug 1, 2015 07:45 AM
blownss27
Jul 20, 2015 08:59 AM
