exhaust cut out and a turbo
Old Sep 8, 2011 | 04:00 PM
TXjeepTJ's Avatar
Default exhaust cut out and a turbo
I want to open my cut out when I go to the track this weekend. I've been reading (google searches, not necessarily on GM based cars) and many people are saying it needs to be tuned with the cut out open if you are to use the cut out
will it screw me up if I open the cut out?
Old Sep 8, 2011 | 10:28 PM
M&M Turbochargers's Avatar
if your gunna try it id keep a close eye on the afr guage
Old Sep 8, 2011 | 10:31 PM
EasyE1986's Avatar
Im SC but i pull my caps at the track. Like said above just watch your AFR
Old Sep 8, 2011 | 11:38 PM
TXjeepTJ's Avatar
what is a dangerous AFR? my tuner said he tuned it for 11.5 (using his own AFR sensor/gauge) when I'm WOT it shows 11.1 though on my gauge. Should I plug it up if I see over 11.5 on MY gauge?
Old Sep 9, 2011 | 02:10 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
IMO, at 8psi, you are good to 11.8-ish, or even close to 12.0 at the higher RPM.
Don't get pissed at me if the **** hits the fan & you blow your **** up though.....
Old Sep 9, 2011 | 04:51 AM
TIM Z's Avatar
11 sec. Truck Mod
Also helps to have good fuel too like 100+ octane for the track days.
Old Sep 9, 2011 | 09:06 AM
i use 12.0 under boost is the shut down area to keep things safe so 11.5 would be good also
Old Sep 9, 2011 | 11:57 AM
silver-mod-o's Avatar
Hunt&Fisherator
tune up for 11.3 through full exhaust, should go to the high 11's with the cutout open... this is depending on how restrictive your exhaust system is too.
Old Sep 9, 2011 | 04:38 PM
TXjeepTJ's Avatar
what is happening literally that causes the AFR to change cutout open or closed?
seems like with the cutout open, nothing should change as far as AFR, since the o2 sensors are still pre turbo. But idk so this is why I'm asking you guys lol
Old Sep 9, 2011 | 06:23 PM
Rick_Vor's Avatar
I was thinking it would only help how quickly the turbo spools up and the MAF (if not SD tuned) and O2's would compensate for it.
I'm sure will chime in with actually results.
Rick
