bigger injectors
I bought some 42lb direct swap injectors for my truck and apparently they are not big enough for my set up. What size should I get if i want to run 14lbs of boost? I dont want to have to waste money on injectors again.
I would get the 60#'s. I picked them up for my 6.0 swap. Nelson has them, or you can find them on ebay. Whippled can fix you up w/ some plug and play adapters for the injectors.
https://www.performancetrucks.net/fo...=412938&page=2
I will be using plug n play 62lb injectors for my build. I just started a post about them here: https://www.performancetrucks.net/fo...42#post3898642
I just started back to the tunning of this truck. I havnt done anything with it for over 8 months. I did a log today and hit about 6lbs of boost and at 4800 rpm my inj duty was 105%. If 60s are a min. should I go with something around 80's?
Pontiac Derek
Sep 19, 2015 01:49 PM
