bigger injectors
Old Apr 15, 2008 | 06:28 PM
macs406's Avatar
Default bigger injectors
I bought some 42lb direct swap injectors for my truck and apparently they are not big enough for my set up. What size should I get if i want to run 14lbs of boost? I dont want to have to waste money on injectors again.
Old Apr 15, 2008 | 07:35 PM
SpoolinChevy's Avatar
I would get the 60#'s. I picked them up for my 6.0 swap. Nelson has them, or you can find them on ebay. Whippled can fix you up w/ some plug and play adapters for the injectors.
https://www.performancetrucks.net/fo...=412938&page=2
Old Apr 15, 2008 | 07:40 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
What method are you using to determine the 42's are too small? I don't doubt they are just curious....I would think 60's a minimum....
Old Apr 15, 2008 | 08:47 PM
bpowell688's Avatar
X2....
Old Apr 15, 2008 | 09:22 PM
sdimer350's Avatar
got my 60's from a guy off tech.
https://ls1tech.com/forums/showthrea...t=60+injectors
Old Apr 15, 2008 | 09:33 PM
SRT10KLLR's Avatar
Former Vendor
I will be using plug n play 62lb injectors for my build. I just started a post about them here: https://www.performancetrucks.net/fo...42#post3898642
Old Apr 16, 2008 | 07:05 AM
THE-HOE's Avatar
do you wanna sell your 42lb ones?
Old Apr 16, 2008 | 09:38 PM
macs406's Avatar
I just started back to the tunning of this truck. I havnt done anything with it for over 8 months. I did a log today and hit about 6lbs of boost and at 4800 rpm my inj duty was 105%. If 60s are a min. should I go with something around 80's?
Old Apr 16, 2008 | 09:39 PM
macs406's Avatar
Oh and yes I would like to get rid of these 42's they have only about 250 miles on them.
OHsixLS3
Sep 25, 2015 11:20 AM
Pontiac Derek
Sep 19, 2015 01:49 PM
Justin87gn
Sep 10, 2015 12:06 PM
Alco
Sep 4, 2015 04:08 PM
lxcoupe
Sep 2, 2015 12:58 AM
