90mm tb ? eldebrock intake ?
Old Aug 28, 2006 | 09:50 AM
  #131
Wilde Racing's Avatar
How do I change this text
Originally Posted by TurboBerserker
I've got a QTP as well. It doesn't leak but make sure you tell them you need metal gears in the motor (ow they are plastic and will fuse together at high boost).
I hope mine is metal, it's already got hot enough to melt the shrink wrap...
Old Aug 28, 2006 | 10:04 AM
  #132
Originally Posted by parish8
i have been out a couple of times trying to tune but am running into some computer issues. i think when i put the batery in the back it changed my grounding enough to cause some problems. i tried an extra ground strap from the motor to the body and it got a lot worse so that kinda tells me i am on the right track but the wrong area.
you know i will post up some performace info once i get thru this and start hammering on it.
Try running a ground from the battery to the cab, useully the firewall is better but since you have the battery mounted in the rear it will be different. I ran into some problems with my 2000 z71 ( not enough ground, when i would raise my windows up -- the dash lighst would come on and the radio would turn off) and I tried alot of things: changed alternator, 1/0 ground from battery to engine and 1/0 ground from battery to frame and none of this fixed it --- Finally I ran a 1/0 gorund from battery to firewall and everything was fixed -- give it a try
Old Aug 28, 2006 | 04:09 PM
  #133
Lord Aries's Avatar
i liked mine too, the 5 days they didn't leak. i tried eveything too.
does the brand you have leak at all? can you send me a pm with a link to more info?
PM Sent...
Old Aug 31, 2006 | 09:14 PM
  #134
FLT's Avatar
FLT
FormerVendor
WTF is going on? No updates!
Old Aug 31, 2006 | 09:40 PM
  #135
XLR8NSS's Avatar
Adkoonerstrator
Old Sep 1, 2006 | 12:14 AM
  #136
Keith's Avatar
Old Sep 1, 2006 | 07:16 AM
  #137
Lord Aries's Avatar
The intake was so powerful that he got going so fast he went Back to the Future!!! Great SCOTT!!!!
Old Sep 1, 2006 | 11:32 AM
  #138
Keith's Avatar
He hit 88mph? No way!
Old Sep 4, 2006 | 08:16 PM
  #139
southern_chevy's Avatar
Before long we are going to have to have another where's parish thread.
By the way parish how is the progress going since I beleive drag week is coming up quickly.
Old Sep 4, 2006 | 09:38 PM
  #140
parish8's Avatar
single digit dreamer
i am having serious problems with my truck. drag week is looking questionable .
here is my problem.
my computer(megasquirt) is seeing tach spikes. megasquirt adds fuel based on a few things but mainly it is rpm, map and the ve map. when the rpm jumps around then so does the fueling. the rpm megasquirt is seeing is jumping around for some reason.
after doing some research it seems this is often caused by interfearance put into the ground system of the truck by any number of things. i have spent many hours trying to track down this problem and am not geting anywhere.
we have tried extra ground straps(motor to frame and motor to body)
a larger power wire from the rear mounted battery to the front
a seperate large ground cable from the battery to the engine
a diferent set of plugs, coil packs, alternator
a 2nd mega squirt
diferent ways of inputing the tach signal into the megasquirt
conditioning of the tach input into the mega squirt
diferent locations for the megasquirt ground
diferent locations for the megasquirt power
unhooking of the tps sensor into the megasquirt
direct input from the crank trigger into the mega rather than the tach output
diferent firmware and diferent software for the mega
unhooking of one coil/injector at a time to see if problem goes away
a few dozen other things.
sometimes the problem would change a little, usualy for the worse. right now it starts and drives fine and revs fine in the drive way but under a load the mega sees the tach spikes and starts dumping fuel.
the problem started with the twin install but was just an ocasional spike. since then the problem has slowly goten worse. i dont know if the intake install caused part of the problem but i dont think so since it was starting to show before the swap. it is worse now though.
i have changed several things, some of the significant.
moved factory computer
extended parts of the main harnes that goto the engine
moved battery to the rear
twins, new manifolds, exhaust....
intake, new tb, new rails, modified fuel system
lots of other little stuff
geek and i spent about 12 hours working on it last night(till 6am), he moved to LA awhile ago but came back to vist and work on some cars. he ended up thrashing on several cars while he was here and got the others all figured out but mine is stumping him along with some other prety smart local guys. today he headed back to LA and now i really wonder if this thing is going to make it for drag week.
