90mm tb ? eldebrock intake ?
Old Sep 5, 2006 | 03:56 PM
  #151
TURBHOE's Avatar
thats not a braided wire on the crank trigger is it? if not maybe you could figure out a ay to make a braided line on it of the sort to make a ground loop on the outer of the wire to ground any interferance you may pic up. hopefully you understand waht i'm trying to say here.
there is a crank sensor current cly and a cam signal hi to lo and cam signal lo to hi. in hptuners. not sure that that will help but if efilive don't maybe some might have hptuners you can use.
Old Sep 5, 2006 | 06:36 PM
  #152
Wilde Racing's Avatar
How do I change this text
Is there anyway to adjust the sample rate of the wideband, maybe it just pull bits slower and doesn't report the spike?
I'm guessing interfearance....
Maybe you could try replacing the wire Crank sensor wire with a twisted pair and a non-insulated ground... but you'd know more about that than me......
Old Sep 5, 2006 | 11:40 PM
  #153
parish8's Avatar
single digit dreamer
i will try a shielded wire to the crank trigger, cant hurt. the original wires just looked normal to me, not even twisted together.
Old Sep 6, 2006 | 09:46 AM
  #154
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Jim, When I was running my MS I had a similar problem right from the start and ended up using much more resistance in my pull up circuit on the tach to get rid of it. I have no clue why this would suddenly occur, but it may be worth a try to through that pot back on the circuit and see if more resistance helps.
AIR, I used significantly more resistance than you did (or than Scott thought anyone would ever need). I couldn't find the exact settings I used, but I found the range of what worked (truck started and ran) to be 150 ohms to 7200 ohms. I think I ended up somewhere around 4900 ohms unless my memory is playing tricks.
Old Sep 6, 2006 | 12:35 PM
  #155
parish8's Avatar
woohoo, i think it is fixed. geek used some vr tach input on the mega instead of the regulur tach input. at first it had the exact same problem but the vr circuit on the mega has extra circuits and potentiometers that allow you to condition the circuit. i turned those pots around and woohoo the problem went away.
i have to goto work now but later i am going to go out and try and tune it. i will know for sure if it is fixed then.
Old Sep 6, 2006 | 12:45 PM
  #156
bigredexpress99's Avatar
congrats man, glad to hear you got it all hammered out.....
Old Sep 6, 2006 | 03:23 PM
  #157
Congrats hope it runs like a bat out of he##,
How about changing you rsig now?
Old Sep 6, 2006 | 08:32 PM
  #158
FLT's Avatar
FLT
FormerVendor
Way to go geek! See you monday!
Old Sep 7, 2006 | 01:59 AM
  #159
parish8's Avatar
did some tuning and it all looks normal. i have a ton of work to do now to get ready. i also need to to fine tune it a little and make a few gtech runs to get it close to the 11.0 i want to run. probably wont be any pushing it till after drag week.
Old Sep 7, 2006 | 02:50 AM
  #160
TURBHOE's Avatar
cool. so you just gona run low boost then? glad everything is work out now. how does that new intake feel now that the mega is working right?
