90mm tb ? eldebrock intake ?
Old Aug 25, 2006 | 05:08 PM
  #121
parish8's Avatar
single digit dreamer
80hp?? i had a nice talk with jeff at induction. he asked me about my cam specs and from his point of view my cam probably has a little too much overlap if i am going to run it thru exhaust. if my exhaust presure is 60psi and my intake presure is 20psi and i have some valve overlap i can see a real power stoper. i wider lsa might fix me up or freeing up the exhaust.
i think the crazy power will come with he cut outs. with just the intake i dont know what it will do.
Old Aug 25, 2006 | 05:45 PM
  #122
GenofiveO's Avatar
Jim I am going to agree with Jeff but you might want to look at this thread near the bottom there is a alot of good info on turbo cams and that overlap is not always that bad
http://www.turbomustangs.com/smf/ind...?topic=66794.0
Old Aug 25, 2006 | 06:26 PM
  #123
parish8's Avatar
everyone there seems to agree free flowing exhaust is needed for the longer duration to not hurt you. i dont think it is a bad cam choice, just that it needs open exhaust once the boost and back presure goes up.
Old Aug 25, 2006 | 08:37 PM
  #124
GenofiveO's Avatar
I can agree with that!
Old Aug 27, 2006 | 07:31 AM
  #125
Lord Aries's Avatar
Dude, electric cuts are the way to go, i love mine!
Old Aug 27, 2006 | 10:02 PM
  #126
parish8's Avatar
i liked mine too, the 5 days they didn't leak. i tried eveything too.
does the brand you have leak at all? can you send me a pm with a link to more info?
Old Aug 27, 2006 | 10:04 PM
  #127
parish8's Avatar
i have been out a couple of times trying to tune but am running into some computer issues. i think when i put the batery in the back it changed my grounding enough to cause some problems. i tried an extra ground strap from the motor to the body and it got a lot worse so that kinda tells me i am on the right track but the wrong area.
you know i will post up some performace info once i get thru this and start hammering on it.
Old Aug 27, 2006 | 10:53 PM
  #128
Wilde Racing's Avatar
How do I change this text
hey Parish I have one QTP cut out, and it don't leak yet, its been on for about four-six months with me driving almost everyday. but it doesn't see as much pressure as your would when it is closed because of it's location behind the turbo. The exhaust just has to go over a axle and through a muffler......
Old Aug 28, 2006 | 08:10 AM
  #129
TurboGibbs's Avatar
I'd run a large guage ground cable back to the engine block if you haven't already.
Old Aug 28, 2006 | 09:07 AM
  #130
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I've got a QTP as well. It doesn't leak but make sure you tell them you need metal gears in the motor (ow they are plastic and will fuse together at high boost).
