20psi 180 IAT's =not that fast
Old Oct 31, 2009 | 03:47 PM
MNC5's Avatar
Default 20psi 180 IAT's =not that fast
Finally got the belt issues figured out and was able to stand on it without the belt coming off or apart.
Makes a bunch of boost but it isn't that fast. I actually liked the 1900 better. So 20lbs with 15 degrees of timing should be fast right. Mid elevens on my GTech on the single run I used it for. I think that's slow for this setup.
Wish I would have kept the 1900 and just squeezed a 100 shot on it. Would have had a 10 second truck without all of the b.s. the 2300 has been. To get this setup into the 10's I feel like I'll need a 30% downhill grade.. I should be happy that I didn't loose another belt and/or pulley today I guess.
If anyone is interested I'm thinking of ditching the 2300 and going to a centri. All offers considered
Old Oct 31, 2009 | 04:00 PM
Mud slinger's Avatar
1 dollar
Old Oct 31, 2009 | 04:01 PM
jow02327's Avatar
belt issues shouldn't be any better pushing a centrifical charger that hard.
^trying to make you feel a lil better
Old Oct 31, 2009 | 04:12 PM
Mangled03gmc's Avatar
Baltimore Whore
You will def need a 8 rib set up to get then psi numbers on a centri... I am slipping the belt at 9-10psi
Old Oct 31, 2009 | 04:55 PM
kbracing96's Avatar
I feel your pain.. 18-20 psi didn't feel like I thought it should on the turbo->supercharger compound setup I had on the truck. Now its gonna have a turbo (BW S480) and a little laughing gas to help spool, or might even spray the whole run depending on what I get out of it.
Old Oct 31, 2009 | 05:18 PM
MikeGyver's Avatar
Modify the fuel system and run E85, it won't care about 185 degree IATs. It will probably like 20 psi and 20 degrees of timing.
DrX's Avatar
DrX
Just guessing the weight of your truck but it sounds like you are in the 700RWHP range with that ET. No torque reduction at launch with the 6L90E I presume. How fast are you ramping the timing down to 15*? What was the starting IAT?
Old Oct 31, 2009 | 05:40 PM
supersub's Avatar
todays ambient temps for the surounding area was @ 42*
Old Oct 31, 2009 | 06:05 PM
CJ Hungus's Avatar
That sucks dude. Sorry things didn't work out like you wanted it to.
Old Oct 31, 2009 | 06:56 PM
leftcoast32's Avatar
FormerVendor
Originally Posted by MNC5
I agree, but everything looks to be working properly. I have concerns about the heat exchanger and might make some modifications in that area.
I also had a 1900 prior to the 2300 and had 130 range IAT's at 12lbs of boost. The IAT's rise with boost too... I might try a couple of Ray's tricks and see if they work to lower my IAT's
I am running over 20psi of boost in warmer temps then you with more timing and dont see IAT's like that. Think maybe you need to look at the build and find the cork you are trying to push through. Likely an exhaust issue to see temps like that, uncork the exhaust and make sure your fueling is good and try again.
Maybe the issue with your engine temps is also compounding the issue with your build!
