TIME SLIP DATABASE
GM guys lets see your 4WD drag set ups!
Old Dec 22, 2014 | 10:18 PM
  #31
Vortec350ss's Avatar
Originally Posted by Atomic
Turbo was a bw s482 and converter a low stall ptc 10.5" triple disc
holy **** thats intense...
what are you gonna do with that hole in the fender and a PD blower? stick your air filter out it
Old Dec 22, 2014 | 11:02 PM
  #32
4WDFTW's Avatar
Looks good I belive iv seen videos of your truck running!
Old Dec 23, 2014 | 07:21 AM
  #33
Atomic's Avatar
I have a gauge for that
Ill probably just put duct tape or something over the hole, or just leave it open for an engine bay vent
Old Dec 25, 2014 | 01:26 PM
  #34
Ok so I went out and installed a bigger wastegate spring that allows me to build more than a 7psi launch...lucky I was 1/4mile from the house because I had to drive home in 4hi. Apparently I will need traction bars to launch on 13psi, because the rear springs wrapped and busted the rear universal joint. Luckily it barely smacked the gas tank and sheared 2 caps off the joint, the ds survived. Time for cal-tracs or Smith Racecraft! LOL!!
Old Dec 25, 2014 | 07:52 PM
  #35
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by 1969x11
At what point do you need anymore than a strapped front end and a ride height that allows the cv's to be flat? This is all i have as of now and i can dead hook on street tires leaving on 7psi and ramping to 18psi.
I had 14 psi just off idle at the launch. When it unloaded the front end, "violent" is a good verb.... It also turned hard left, which will scare the **** out of you pretty quick, and the pucker factor gets pretty high.
The track manager(in my case track owner) was not impressed or happy about it.
With straps & CalTracs, and drag radials, I could still have some tire spin on the launch, but it became manageable.
Old Dec 25, 2014 | 10:05 PM
  #36
Before I strapped the front it would buck a little and pull hard left. The straps fixed that problem but my truck was lazy to build boost with the 5lb spring in the gate. With the 9lb spring the boost comes on violently and this morning was the first time I have tried to launch over 8psi. I think I'm gonna go with the Assassin bars and some adjustable rear shocks
Old Jan 25, 2015 | 04:34 PM
  #37
Bringing this back up...I got my bars put on and adjusted. Now I spin for about 20 foot and it finally hooks(street tires) LOL!! Now I need a $1200 set of drag radials. Does everyone recommend the M&H 275/50/17's ??
Old Jan 25, 2015 | 06:35 PM
  #38
GMCtrk's Avatar
I prefer the MT ET street radials over the M&H (which tend to run small)
Old Jan 25, 2015 | 07:40 PM
  #39
Those would be about 400 bucks cheaper but I would have to step down to 16's. Who has ran 4 of these on the street?
Old Jan 25, 2015 | 08:56 PM
  #40
Atomic's Avatar
I used to use that size m&h, they worked pretty good! Very soft though, maybe 10k street miles tops.
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
MileHighSierra
Jul 22, 2015 11:19 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
