GM guys lets see your 4WD drag set ups!
Looking for pics of what everyone is running as a 4WD wheel and tire combo for the Street/Strip. Post a pic of your set up and details on it! I'm pretty sure I'm going with the dark stars 17x9.5 on all 4 corners but want to see what everyone else is running first.
2 Attachment(s)
I've heard of clearance problems with the 9.5" wheel up front.
I run stock denali wheels with the m&h 275/50r17. 2 of the tires are more or less shot so when the time comes I'll get 2 race stars 17x9.5 and run the 325 out back. |
1 Attachment(s)
Attachment 96130
M&H Racemaster drag radials on Centerline billet wheels, and a little bit of suspension work. Any questions, just ask. Yes it's a 4x4. |
Wonder if I could get a different offset for the front to not rub? Do you know if they run the frame or the finder?
AK truck looks good! What size tires? What do you have for lowering? I want to be sitting at about that same hight.
275/55R16, which is a 28" tire. Wheels were 16x8.5 IIRC.
Out back, I had lowering shackles, removed block, removed overload, and CalTracs. Up front I had lowering keys, aftermarket UCA eccentrics, tie rod sleeves, and adjustable limiting straps. It was around a 3/5 drop. |
Originally Posted by AKlowriderZ71
(Post 5262612)
Out back, I had lowering shackles, removed block, removed overload, and CalTracs. Up front I had lowering keys, aftermarket UCA eccentrics, tie rod sleeves, and adjustable limiting straps. It was around a 3/5 drop. Thanks for the info! |
I'd like to see more about the tie rods too roger. I gotta upgrade those...
(Post 5262619)
They are. Same exact ones I have on my Duramax.
