tune problems
Old Dec 28, 2012 | 01:22 PM
Joe4.8silvy's Avatar
Default tune problems
So i got a dyno tune awhile back and i noticed every here and there it would surge when i came to a stop, then the other day im driving and and go to kick in passing gear and where it use to shift it didnt the rpms kept climbing to 6k but it acted like i hit red line and the motor kept going but the trans didnt my shift points are messed up at wot.then my check engine light came on and the tune did have it so that didnt show up so i think somer how my tune got messed up any one have any clue ?
Old Dec 28, 2012 | 01:42 PM
03sierraslt's Avatar
So what was the code?
Old Dec 28, 2012 | 02:24 PM
It was an o2 code bc I punched my cats out the tune was suppose to have that so it didn't pop up which it did for a while then all if a sudden it's all messed up, I called my tuner and explained it and he said its not the tune but I believe it is
Old Dec 29, 2012 | 07:58 AM
8 Second Club
You can not have a good tune suddenly go bad.
If things were running good and suddenly they started running bad, it is because something changed.
Could be related to punching the cats out, or related to your tranny going out.
Old Dec 29, 2012 | 10:05 AM
The cats were punched out b4 I got the tune and the trans shifts perfectly under light throttle and any thing under wot, the truck was just at the dealer ship for body work idk if they hooked the tech 2 up and did something or why they would even touch that but after I picked it up that's when it started I also noticed my sub was turned all the way up along with my radio
Old Dec 29, 2012 | 10:08 AM
2000chevysilverado's Avatar
Sounds like somebody at the dealership unhooked something do a good go over to see if all is plugged in and I would call them and tell them that who ever drove your truck blew up your stereo
Old Dec 29, 2012 | 10:17 AM
Yea ill double check every thing, and I know every time I take my truck to a dealer thy all ways do that I guess I'll have to give them a call thanks for the advice guys
Old Jan 9, 2013 | 11:41 AM
csstuner's Avatar
Registered User
I don't see a tune changing. Sounds like two differnt problems. The idle might be the tune. The transmission problem sounds like a issue with the transmission.
Last edited by 1FastBrick; Jan 11, 2013 at 11:12 PM. Reason: Non Sponsor info removed
Old Jan 9, 2013 | 01:57 PM
custom 68's Avatar
yea it sounds like your transmission or converter is slipping. I am not sure what I read on your post. Did it downshift but would not upshift? check all your wiring to your tranny.
ferrellrooster
Mar 6, 2025 03:22 PM
mr03silverado
Jun 26, 2016 06:05 AM
shawn96gmc
May 17, 2016 04:15 PM
pittman
Jan 19, 2016 07:06 AM
lxcoupe
Jul 14, 2015 10:14 PM
