Throwing o2 sensor code
Old Jun 14, 2011 | 09:14 AM
ethanbrogden's Avatar
Default Throwing o2 sensor code
I have a 2004 Chevrolet Silverado 1500 RCSB with a 5.3. The truck has a K&N FIPK cold air intake, flomaster duels, and the previous owner said it was programmed. The truck recently threw an o2 sensor code for all of the o2 sensors, so I replaced them all. About 50 miles down the road it threw the same code again. So, do I need to get the truck reprogrammed or what?
Old Jun 14, 2011 | 02:31 PM
blueflamed03's Avatar
did you pull battery cable and reset computer, or go have codes erased?
Old Jun 15, 2011 | 04:40 AM
kostelacd69's Avatar
Start with basics. Check fuses ect. 4 o2's dont die all at the same time. There are 2 fuess to check in the underhood fuse box. both are 15amp fuses, o2a and o2b. one fure for each set (b1&2s1 and b1&2s2). Maybe that helps. There also was a TSB for the o2's getting water in them and breaking. they recommend replacing the broke o2 and doing a reflash for the latest update. hope that helps.
Old Jun 15, 2011 | 04:42 AM
Just wondering what code(s) are you getting?
Old Jun 16, 2011 | 01:14 PM
I think I have it straightened out. The gas station that i was getting my gas at had 10% ethanol in thier gas, and ethanol will atract moisture. So I went and tried another station without ethanol and the light went back out.
Old Jun 19, 2011 | 08:34 PM
The light came back on, it is saying bank 1 sensor 1&2 low voltage and bank 2 sensor 1&2 low voltage. I checked the fuses that were stated earlier, but they were still good. I am out of ideas...
Old Jun 20, 2011 | 12:54 PM
Bump! Guys I really need some help!
Old Jun 20, 2011 | 01:44 PM
Gordy M's Avatar
You need a good scan log to determine your problem otherwise your just going to chase symptoms and not the source. It could be a number of things like a vacuum leak, ground, bad battery, etc but without a good scan log it is hard to chase your problem.
Old Jun 21, 2011 | 12:26 PM
My mechanic said that he checked for vacum leaks, shorts or messed up wires, fuses, he cleaned the air filter and he verified that the O2 sensors are still good. Would a dirty or broken MAF sensor be causing this issue?
Old Jun 21, 2011 | 01:08 PM
dewmanshu's Avatar
Moderately Differentiated
post up the specific codes. Like P0131. All of them.
