shift points
Old Sep 21, 2007 | 02:01 PM
xchevyx24's Avatar
Default shift points
i have been messing with my shift points for awhile now i cannot get a good shift from 1>2 what speed/RPM are u guys shifting at?
Old Sep 21, 2007 | 05:37 PM
06chevycrew's Avatar
From 1 to 2 i'm shifting at 6000. 2 to 3 at 5900
Old Sep 21, 2007 | 05:52 PM
xchevyx24's Avatar
what speed?? if u have 3.73's
Old Sep 21, 2007 | 11:06 PM
cmitchell17's Avatar
Im shifting at about 5600-5700rpm which it really shifts about a 100-150rpm higher. I think it looses to much power after 5800 to rev it past that, but it also drops down to 3000rpm in 2nd with the tall 2nd gear ratio.
Old Sep 22, 2007 | 01:46 AM
nonnieselman's Avatar
I ran my best times shifting at 6000... 1-2 and 2-3... Before the Turbo...
Are you using HP Tuners?
I wouldnt worry about the speed,,, just use the RPM...
Old Sep 22, 2007 | 05:58 PM
xchevyx24's Avatar
Yea Im Using Hp Tuners So Should I Just Leave The Speed Stock And Mess With The Rpm's?
Old Sep 25, 2007 | 10:36 PM
Unless you go to a shorter tire you can leave your MPH alone.. Ive always used RPM and not had any problems.
Old Sep 26, 2007 | 09:30 AM
KY_BOB's Avatar
Me too.
I'm shifting at 5950 for both shifts. I think I'm going to do a cam/spring/push rod change just so I can spin it a little more. At 5950 the boost is building fast and I want it to build a little more.
Old Sep 28, 2007 | 11:41 AM
gmforlife's Avatar
just stick to rpm's, if you mess with speed and raise that too high you'll hit the rev limiter before it shift because it's trying to get to that speed before it shifts. Keep speed to stock, rpm's only IMO
Old Sep 29, 2007 | 09:36 AM
HD6.0l's Avatar
Banned
Added 10 mph over stock , plus rpm increase .
MikeD.
Oct 13, 2015 08:08 AM
jtphelps289
Sep 29, 2015 12:00 PM
Lthompson
Sep 15, 2015 07:55 PM
TAPyvehc93
Sep 14, 2015 01:22 PM
xerox17
Sep 5, 2015 01:23 PM
