reduced engine power code HELP
Old Apr 12, 2008 | 11:05 AM
Default reduced engine power code HELP
i just finished p&p my TB on my 04 5.3 and i put it back on and started it. It sounded like it was missing for about two seconds and then it was idling a little high and then "reduced engine power" came up on the display. I unplugged the bettery and im letting it sit for a while and im gonna go try it again. What could it be?
Old Apr 12, 2008 | 11:52 AM
jesus christ cylinders 2, 4, and 8 are down. WTF did i do.
Old Apr 12, 2008 | 01:54 PM
im getting TPS codes right now. why would that cause those cylinders to not work? And how do i fix it?
Old Apr 12, 2008 | 04:29 PM
outlawz2004's Avatar
ttt for ya. Interested to see the outcome.
Old Apr 12, 2008 | 06:14 PM
hyespeeder's Avatar
Did you take off the senors when you port and polished it?
Make sure the contacts are clean and that nothing got into the motor for the throttle and the tps sensor . Check all wires
Old Apr 12, 2008 | 06:20 PM
ok its still doing it and i cant figure it out. Im gonna try to find someone with an 03-05 v8 so i can switch the tb and see if thats the problem. I just dont understand why its doing it. i cant rev it past 2,000 and it takes forever to get there. PLz, any help will be appreciated.
Old Apr 12, 2008 | 06:26 PM
i didnt take it apart bc its riveted together and i didnt feel like messing with the return spring. i had the idle air control motor hole blocked with a piece of plastic so i dont think anything got in there. ill check it out though. thanks for the input. i really need to figure this out bc i need to go back to college tomorrow
Old Apr 14, 2008 | 07:30 AM
so i guess ill just get a whole new tb and reflash the computer, i hope that will fix it.
ARC
57
Feb 21, 2022 10:54 AM
thunder550
Oct 8, 2015 04:53 PM
Ketis
Jul 23, 2015 12:37 PM
bsgiffor
Jul 19, 2015 11:14 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
