help, truck wont start!!!
Old Feb 12, 2008 | 12:49 PM
US ARMY LS1's Avatar
Default help, truck wont start!!!
i have replaced the starter and had the batt. tested. i have full power in side but when i turn the key to start, nothing happens. WTF!!!! this is a 98 gmc jimmy 2wd with a vortec 4.3
Old Feb 12, 2008 | 12:58 PM
truckmann's Avatar
Have you checked all your ground connections to the battery and starter?
Old Feb 12, 2008 | 02:42 PM
sleepersilverado's Avatar
first thing i would do is stick a meter on the starter solenoid and turn the ignition on like you are going to start it (on the signal wire). If it has power then there is a problem down around the starter. If there is not power then it is on the other end ie: fuse, realy,ignition...
Old Feb 12, 2008 | 05:34 PM
Grumpy5.3's Avatar
check your fusible links on the inside of the drivers side fender near the brake booster
Old Feb 12, 2008 | 08:03 PM
joshua022's Avatar
I've gotten bad parts before...the starter might have you chasing ghosts. just a thought
Old Feb 12, 2008 | 09:32 PM
00Silv4.8's Avatar
I agree with the solenoid. turn the key on and touch a screw driver to the 2 bolts.. make sure its got a handle too, and if it doesnt spark is the solenoid, but if it does it should start if Im not mistaken
Old Feb 14, 2008 | 07:29 AM
mcfarlnd's Avatar
Un-Registered User
i had same problem and it was the ground that went to the engine block from the battery.
Old Feb 14, 2008 | 08:06 AM
Nick™'s Avatar
well... looks like every one posted my two ideas already haha... so I'm just posting to ***** up the thread.
but I do agree, you need to test the wires at the starter for proper current and check ground wires - either would be the most common issues found with those symptoms.
Old Feb 14, 2008 | 09:11 AM
budhayes3's Avatar
PT's Slowest Truck
As mentioned, make sure that you're getting 12v to the starter solenoid. If not, check for a voltage drop along the starting circuit. Another idea that comes to mind is possibly a bad ignition switch.
wrb002
Aug 31, 2015 12:00 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
Ketis
Jul 23, 2015 12:37 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
black6spdz
Jul 16, 2015 01:32 AM
