Bigger injectors
Old Nov 28, 2005 | 01:16 PM
Zick's Avatar
Default Bigger injectors
Can I put in say 42lb injectors and just tune the PCM for it, or will that cause problems.
Reason I ask, is I alway see 8.1 marine injectors for sale but all I want is the regular 8.1 injectors (30lbs)
Old Nov 28, 2005 | 01:24 PM
kbracing96's Avatar
Yes, you just need the IFR table rescaled for the larger injectors and it will run fine with either 30lbs or 43lbs.
Old Nov 28, 2005 | 03:24 PM
Zick's Avatar
So basically instead of the 25.24 that is there for factory 24lbs, I can just put in the correct ##'s across the board and it will be ok.
Is the Injector Flow Rate vs. KPA VAC the only table I need to mess with?
Thanks
Old Nov 28, 2005 | 03:43 PM
kbracing96's Avatar
yep
Old Nov 28, 2005 | 09:13 PM
Dark Halo's Avatar
I have a new take off set of the 8.1 truck injectors that came off a crate motor. They were only used for testing. PM mean offer I may be selling them Because I need the marine injectors.
Old Nov 28, 2005 | 09:48 PM
Zick's Avatar
Thanks KBRacing96
You got a pm.
Old Nov 30, 2005 | 03:27 PM
02gmcwaldoch's Avatar
whats the differance between the 8.1 and the 8.1 marine injectors?
Old Nov 30, 2005 | 04:14 PM
kbracing96's Avatar
Standard 8.1 truck injectors are 31 lbs/hr and marine 8.1's are 43 lbs/hr.
OHsixLS3
Sep 25, 2015 11:20 AM
Pontiac Derek
Sep 19, 2015 01:49 PM
Justin87gn
Sep 10, 2015 12:06 PM
Alco
Sep 4, 2015 04:08 PM
lxcoupe
Sep 2, 2015 12:58 AM
