Bigger injectors
Can I put in say 42lb injectors and just tune the PCM for it, or will that cause problems.
Reason I ask, is I alway see 8.1 marine injectors for sale but all I want is the regular 8.1 injectors (30lbs)
So basically instead of the 25.24 that is there for factory 24lbs, I can just put in the correct ##'s across the board and it will be ok.
Is the Injector Flow Rate vs. KPA VAC the only table I need to mess with?
Thanks
Thanks
Thanks KBRacing96
You got a pm.
Originally Posted by Dark Halo
I have a new take off set of the 8.1 truck injectors that came off a crate motor. They were only used for testing. PM mean offer I may be selling them Because I need the marine injectors.
Pontiac Derek
Sep 19, 2015 01:49 PM
