Anyone else have rich idle issues with 42/44lb 8.1L marine injectors
Old Nov 4, 2011 | 11:51 AM
BlackGMC's Avatar
Resident Retard
Default Anyone else have rich idle issues with 42/44lb 8.1L marine injectors
Well i have been having a issue for awhile with these marine injectors. My trims go WAY negative at idle with the truck ingear. Well i am decelerating right at 1200rpm the trims start going negative. But in park they are fine. Yes i could bastardize my throttle cracker table to compensate but that is not the right answer. I have tried adjusting all the pulse width tables and it has yeilded limited results. I have tried using my stock injector values and adjusted the IFR no help. I have also tried using stock 8.1l injector values and adjusting the IFR and no help. Just wondering if anyone else has this issue.
Old Nov 4, 2011 | 12:07 PM
Atomic's Avatar
I have a gauge for that
Make sure the VE table is correct in those areas and have you tuned the base running airflow table?
Old Nov 4, 2011 | 12:15 PM
BlackGMC's Avatar
Resident Retard
The VE is pretty accurate, and the base running airflow table is within reason... I have added and subtracted values from the desired airflow table and it had not affect... I need to do more logging, i am starting think it may not be the injectors and may be related to Transient closed throttle settings....
Old Nov 4, 2011 | 12:25 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
MAF going bad? Try a known good MAF if you can get your hands on one.
Old Nov 4, 2011 | 12:27 PM
BlackGMC's Avatar
Resident Retard
MAF is good and steady at various loads and RPMS, I don't think it is issue, because when i tune in SD, the same issue occurs....
Old Nov 4, 2011 | 11:58 PM
Happens in open loop AND in closed loop?
I'm just trying to think out loud here. Sorry if I'm being redundant.
Old Nov 5, 2011 | 07:20 AM
Gadgetized's Avatar
Is this on your truck? How big is the overlap on the cam? I put 60's in my truck, and had to put the min pulse width in the negative to get it to work properly. I wouldn't think you would need to do that with marine injectors. Did someone possibly increase the flow in them?
Old Nov 6, 2011 | 07:45 PM
BlackGMC's Avatar
Resident Retard
Well i spent the day dicking with the truck. I took off my ypipe and put a
Flat file to all the vbands, they were not completely flat from the black on the the passenger side was leaking a little bit. I ditched the TR6s and put in some new TR5s. I recalibrated my wideband too.
Next i started over with the tune. I used a 2004 8.1L injector setting except for the flow rate. I adjusted it for the 42lbers.
Redid the VE and MAF and the problem was still there on wierd occassions. So i got to digging. I made a map of the throttle cracker table with the BEN factor fromy LTFTs. LOW AND BEHOLD that was the problem. I had WAY to much in some areas and not enough in others. Made some adjustments and it is doing tons better.
Old Nov 6, 2011 | 07:49 PM
Atomic's Avatar
BEN factor?
Old Nov 6, 2011 | 07:53 PM
GMCtrk's Avatar
Originally Posted by Atomic
BEN factor?
base efficiency numerator, I believe.
