Anyone else have rich idle issues with 42/44lb 8.1L marine injectors
Old Nov 7, 2011 | 12:19 PM
  #21
BlackGMC's Avatar
Resident Retard
after some reading on EFI Live, i am gong to try lowering the small pulse adjust by 50% in the affected areas... this problem started when i put back in the stock Torque Converter
Old Nov 8, 2011 | 11:40 AM
  #22
BlackGMC's Avatar
Resident Retard
Well another update. I tried lowering the pulse widths tables. It had zero effect. I even zeroed out the pusle widths table also zero affect. So to rule out the maf, i put the truck in SD. I did forget to copy the high octane table down to the low so the truck is sluggish as ****. But the rich decel is gone!!!! However the trims while in park are rich now but in gear they are good. Soooooo i am thinking i need to lower the desired airflow in park/neutral and get a new MAF.
Any thoughts on that??
Old Nov 8, 2011 | 03:55 PM
  #23
AKlowriderZ71's Avatar
11 Second Hall Moniter
Sounds to me like you're on the right track now. You likely tuned your idle airflow tables with a bad MAF, or the other torque converter affected your idle airflow tuning differently. Just my guess though.
Old Nov 8, 2011 | 08:50 PM
  #24
BlackGMC's Avatar
Resident Retard
Ya i nasically kept all the old settings from the previos 2 torque converters that were in my truck.
Man running on my low octane table SUCKED. Try getting on the highway with 6* of timing. The damn truck was bucking like a ****.
Old Nov 8, 2011 | 08:53 PM
  #25
BlackGMC's Avatar
Resident Retard
Another update. Finally updated the low octane table, it actually has some power now. I logged the idle and corrected via trims. Next took it for a drive. The highest the trims got were +2.0 and the lowest was -1.7. That was about a 20min log!!! The truck drives 110% better. Now i gotta start shopping for a maf.
Old Nov 8, 2011 | 11:08 PM
  #26
I suppose that's good news. Reman MAF's are pretty cheap at the parts stores.
Old Nov 8, 2011 | 11:36 PM
  #27
TXsilverado's Avatar
/maf
Old Nov 8, 2011 | 11:47 PM
  #28
BlackGMC's Avatar
Resident Retard
Actually i have been doing some reading on the corvette and on ls1tech, i think i am going to switch over to the new card style maf.
Old Nov 8, 2011 | 11:53 PM
  #29
I'd be interested to hear about this. It can be put into a 4" tube, and recalibrated, right?
Old Nov 8, 2011 | 11:56 PM
  #30
/maf
+1
