Anyone else have rich idle issues with 42/44lb 8.1L marine injectors
Resident Retard
Actual/Expected=BEN
For example:
Actual AFR/Commanded AFR = BEN
14.00/14.68= 0.95
If you were tuning VE, you could multiply that cell by .95, thus lowering it thus making it leaner...
Another example LTFT:
1 + (({SAE.LONGFT1} + {SAE.LONGFT2})/200) = BEN. I made this custom PID to average both banks and put them in a BEN format (1.05, 0.95, etc...
Here is one for the STFT
1 + (({SAE.SHRTFT1} + {SAE.SHRTFT2})/200)
Here is one to see the difference between VE and MAF to see if your tuned properly..
GM.CYLAIR_DMA}/{GM.DYNCYLAIR_DMA
For example:
14.00/14.68= 0.95
Well i spent the day dicking with the truck. I took off my ypipe and put a
Flat file to all the vbands, they were not completely flat from the black on the the passenger side was leaking a little bit. I ditched the TR6s and put in some new TR5s. I recalibrated my wideband too.
Next i started over with the tune. I used a 2004 8.1L injector setting except for the flow rate. I adjusted it for the 42lbers.
Redid the VE and MAF and the problem was still there on wierd occassions. So i got to digging. I made a map of the throttle cracker table with the BEN factor fromy LTFTs. LOW AND BEHOLD that was the problem. I had WAY to much in some areas and not enough in others. Made some adjustments and it is doing tons better.
thats alot of work, the wife out of town?
Resident Retard
Well ****. It is back. Same issue with some new issues. Trims are negative with truck ingear below 1200rpm. Something new the trims go way positive when let off the throttle crusing around 60mph. I am thinking it is throttle cracker in the upper MPH may e running airflow at lower rpms. Such a pain in the ***
