Headlight Mod for $1
Old Dec 11, 2004 | 05:08 PM
  #21
agreif's Avatar
Ground the wire that comes from the box. The wire in the loom I just taped off. You'll see my wire is green from the box,m that's because I took the yellow wire out of the connector and just put a new wire that I ran to a ground point.
Andrew
Old Dec 11, 2004 | 09:03 PM
  #22
bodyguard6799's Avatar
I have an 01 Seirra and my relays arnt setup like that. I have on big relay for hi and low lights and 2 seperate ones for drl and fogs. Can I still do the diode mod?? I just want my lows on with hi's and fogs on with both. I dont really car about the drls. THANKS!!
Old Dec 12, 2004 | 10:51 AM
  #23
Anyone??? I would really rather do this than have to cut wires or buy a kit. THANKS
Old Dec 12, 2004 | 11:44 AM
  #24
seal20's Avatar
You can't do the "diode thang" on 99-02....gotta cut or buy a kit.
Old Dec 12, 2004 | 06:37 PM
  #25
04BlackSilverado's Avatar
Well......
I think you could.
I dont know anyone with a 99-02 near me in New England.
But, I think if you look in the relay box for the Highbeam and lowbeam relays. Find the signal to the relay coil. Put the Diode between the signals. That should work.
Anyone have a 99-02 near me that wants the mod for free, I'll do it for ya?
The yellow wire is a MUCH easier mod to do though.
Old Dec 14, 2004 | 07:14 PM
  #26
Further Understanding
The diode has one side that has a white bar. The white bar should go twards the High Beam signal (T1). The bar should always point twards the trigger. The other end of the diode should be in the Lows (B4) And ANOTHER diode should be used for the fogs, with the bar twards T1 like the other. But this time the other end goes in the Fog (B5) Like the Attached Pic.
File Type: bmp
Old Dec 15, 2004 | 03:22 AM
  #27
yoskater's Avatar
Might have to try this!!
Old Feb 8, 2005 | 07:33 PM
  #28
Anyone had problem with this setup yet?
Mine is still goin strong!!!!!!!!
Old Feb 8, 2005 | 07:39 PM
  #29
oh yeah UNPLUG THE CONNECTOR WHEN WORKING ON IT!
HAVE THE KEYS OUT OF THE IGNITION WHEN INSTALLING THE DIODES (incase you touch the wrong wire, you won't F it up)
Old Feb 9, 2005 | 03:58 PM
  #30
can i run my drls at night, i wanted to run them with the turn signal lights. sorry for the hijack
