Headlight Mod for $1
#41
OK WTF!!!!! i did ecactly keukaz71 said to do. i cut the yellow wire and then i connected more wire to the yellow wire to make it longer then i screwed it to the corner of the inside fender. i did the drivers side first-when i turned on my headlights the drivers side stayed off and the pass side went on. then when i turned on my hi beams both the hi's and lows on the pass went on and the drivers hi went on but the drive low stayed off. ok then i did the same thing to the pass side but when i finished niether side lows went on and when i turn on my hi's both go on but not the lows!!!WTF? so now i dont have any lows what so ever... SOMBODY ANYBODY PLEASE HELP ME!!!!! im not sure if it was the type of wire i used but what gage is the orig. yellow wire?? i need help asap.....where did i **** up????
#43
here are the pics. hope you get it resolved.
in this pic, look at the left bulb, that is the low beam, see the orange and yellow wires, the yellow you cut and ground. make sure you ground the one that came directly from the light bulb, leave the other yellow end alone, it goes to the fuse box probably
this pic you can see the blue wire in the bottom right. i attached this wire to the yellow wire that came directly from the light housing. i used a butt connector. sand the paint where the ground is.
this last pic, you can see the blue wire that i attached to the yellow ground, although it is covered up with electrical tape and stuff
#44
i grounded mine under the radiator core support with no problems. theres a bolt right underneath the little thing to adjust the hood.
i found the relays for the foglights and headlamps on my 2001. which posts on the relays do i put a diode inbetween to get the fog lights to come on with the brights?
#46
do you have a diagram of what you need to connect to get every light in the front of your truck to light up, the lows, highs, drl, pk lamp/turn signal, fogs everything thanks
#50
Originally Posted by *WILDSTYLE 5.3*
thanks for the help guys but the day i posted my q i figured out what i did wrong. yester day i made my drls part of my trurn signals. i love the way it looks now!!!
Bryan
