Zachm89's Turbo SSS Build
Old Feb 4, 2015 | 01:33 PM
  #31
03sierraslt's Avatar
Vac blocks work good, I have one also (different brand) but they help clean things up.
Old Feb 4, 2015 | 01:35 PM
  #32
zachm89's Avatar
Well step up to the plate and post up a pic of where you have yours mounted.
Old Feb 4, 2015 | 01:54 PM
  #33
Don't have any pics handy, mine is mounted in the corner where the drivers side fender meets the firewall. It's kinda under the fender brace and hidden just like I want it.
Old Feb 4, 2015 | 02:03 PM
  #34
zachm89's Avatar
The sounds promising, should have plenty of room over there once the hydroboost goes in. Thanks!
Old Feb 4, 2015 | 04:23 PM
  #35
zachm89's Avatar
First post and parts list has been slightly modified
Old Feb 4, 2015 | 04:46 PM
  #36
zachm89's Avatar
Trick manifold and Precision WG should be here in a week or so
Old Feb 4, 2015 | 05:12 PM
  #37
George C....'s Avatar
Formerly ScreamingL
never found a reason to ever need a vac block on a turbo setup, curious why you need one on a PD setup as well
Old Feb 4, 2015 | 05:16 PM
  #38
zachm89's Avatar
How else do you suggest running vacuum lines to BOV, gauge, FPR, catch can, MAP sensor, EVAP (if applicable), etc without t'ing everything together and making a mess of t fittings and vacuum lines? I think with the vacuum block it will just make everything a lot easier and tidier under the hood for vacuum line routing and distribution to everything that needs a vacuum source.
Old Feb 4, 2015 | 05:42 PM
  #39
Formerly ScreamingL
In the last 8 turbo builds and 1 procharger build ive done, ive yet to ever need a block and always looked clean
first catchcan never goes to intake....valve covers and valley cover into catchcan/breather setup and that is it
No evap with boost
you have 1 line going to BOV
you have 1 line going to FPR
you have 1 line going to Map that tees to the boost gauge when using a holley setup
car intakes ive stabbed the map in the intake itself
or incase of GMT900 intake you use a stock style 3 bar map that plugs into the stock location
if using stock style map sensor then 1 line to boost gauge.
most intakes have enough ports to feed off of for reference
ive used fast intakes, holley intakes, Vic juniors intakes, ls6/ls3 intakes, proflo intakes and GMT800/900 intakes all with same layout
Old Feb 4, 2015 | 05:55 PM
  #40
Vortec350ss's Avatar
This minus a few things... just to make things cleaner. Boost gauge, FPR, Meth MAP... just a few things I want accurate readings for that I dont want to have to rely on T fittings for. The maggie only has 1 port.
