Walledition-New Project: Boost/Turbo-Fuel/Return System, Build
Old Feb 8, 2016 | 11:34 AM
  #81
walledition's Avatar
Originally Posted by George C....
I cut that crossmember out, made a new one that rises up closer to bed..try to keep shocks at 90* or leaned as much as say 10*
If ya gonna do it may as well stand them up correctly, also keep them as far apart as possible for leverage control
Pics are in my build thread amd i used 1 5/8 tube
i just looked it up it looks good, thanks for the tips, question: why do i want the bar as high as possible? why cant i cut a hole on each side of the frame and weld it it like the stock crossmember is?
Old Feb 8, 2016 | 11:37 AM
  #82
Originally Posted by Atomic
I just put both to the same factory crossmember, but I think yours is lower than mine. You could probably remove that factory tube if you are putting a new one in.
What your saying makes me think, if i dail it in exacly how it needs to be with the 2/4 drop i have now and decide to go lower later it will change the degree of the shocks
Old Feb 8, 2016 | 11:44 AM
  #83
George C....'s Avatar
Formerly ScreamingL
You want the longest shock possible...you want 5"+ of travel
Short shocks **** ya with a caltrac setup...extension is key...so set shocks up with 1.5-2" of remainding compression and rest extension
Example my shocks are 24.5" long and roughly 5" drop in rear
Old Feb 8, 2016 | 11:45 AM
  #84
Atomic's Avatar
I have a gauge for that
If it is directly above it, no. If its offset, then yes the angle will change. That's probably why George said as high as possible, to give you the most flexibility with the angles and placement. Its also easier to fit a shock given a larger space vs a smaller space.
Old Feb 8, 2016 | 12:26 PM
  #85
Good points right there, i´ll post pictures as i go
Old Feb 12, 2016 | 12:49 AM
  #86
Picked up some bling at bogarts on my trip, met Rich in person, great and helpfull guy to deal with
Old Feb 12, 2016 | 10:22 PM
  #87
JordanH's Avatar
Restricted
Originally Posted by walledition
Thank you, yeah ive been there a couple of times, its a 5 to 6 hours drive so i dont go to often, do u ever go?
Yeah... I'm down here right now getting some logs on this motor I just built for my buddy's Pontiac gxp! When you get back up this way let me know! I'd like to check that truck out!
Old Feb 13, 2016 | 12:25 AM
  #88
Sounds good
Old Feb 19, 2016 | 04:22 PM
  #89
Updates:
Shocks stock location:
Parts i cut out
After cutting
New Wheels
17x7 D10´s street/strip fronts
15x10 D10´s street strip rears
Brackets for new shock locations
After everything installed shocks came out at 5 degrees
Question i have is why does everybody weld the crossmember like this and not laying on the frame like i did? i measured under my bed and i have the room for it, dont u want it as high as possible?
Crossmember isnt fully welded in i can still make changes that why im asking
Old Feb 19, 2016 | 04:39 PM
  #90
JordanH's Avatar
Restricted
Those rims are nice!!! Gonna look like a completely diffrent truck with those!
