Spoolin's attempt to Spool...
Old Jan 30, 2011 | 01:03 PM
  #331
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Originally Posted by Spoolin
Oh ok! Than yeah, I am familiar with those. Simple enough! Thanks, I'll head down and grab a 5/8" disconnect tool. Didn't even know they made those, that would certainly be easier then using screw-drivers like I usually do!!
Thanks
Old Jan 30, 2011 | 01:23 PM
  #332
joeyc125's Avatar
11 Second Truck Club
Thanks
Lol, for some reason I know exactly what you are talking about. The tool is definitely alot easier than poking 3 plastic tooth picks in there like I have "heard" of people doing
Old Jan 31, 2011 | 07:13 PM
  #333
Spoolin's Avatar
GFYS and STFU
Well I bought the quick disconnect tools...and what a PITA!!
I ended up hacking them off anyways!!
Anywho...moving on...
Old Jan 31, 2011 | 09:15 PM
  #334
jared91's Avatar
whats the list of broken stuff at now?
Old Jan 31, 2011 | 09:51 PM
  #335
Spoolin's Avatar
GFYS and STFU
I've broken more things than I've assembled/put together so far!
OK so, I'm running out the door here but here's a small small tiny update...
I "gutted" the middle line (I think it used to be the EVAP) and am gonna use that as a vent.
Here's what's left of the check valve that is part of that line...
And the hole that it occupied...
I also drilled out the line/pipe to enlarge the inner diameter so that it would not be so small as to allow the tank to pressurize...
Now it's about 1/4" of so.
I also drilled a hole through the top of the bucket and installed a grommet...
ran the wires...
And haven't decided how I'm gonna seal it. I have plastic welder, JB weld and Gray RTV, I'll probably do a combination of them tomorrow.
Also re-wired the bucket so that the stock wiring works on one pump, the other one will be activated when I switch to Hi on the boost controller.
I hope I didn't mix up the plug wires!!
I'm gonna flush out the system tomorrow morning before doing final assembly. I also ran the power supply from the aft mounted battery all the way up into the engine bay. I ran it inside the frame rail inside some Irrigation tubing to protect it. I think it looks really well hidden and kinda stock. I'll take pictures of it tomorrow when I get some more time.
Old Jan 31, 2011 | 09:59 PM
  #336
Bigredmariner's Avatar
Looking good man, I love the reference to the "aft" battery. Nice job mate.
Old Jan 31, 2011 | 10:35 PM
  #337
Atomic's Avatar
I have a gauge for that
Shouldve saved yourself the trouble and just bought my bucket
Old Feb 1, 2011 | 02:17 AM
  #338
Spoolin's Avatar
GFYS and STFU
I was trying to think of another way to say it to be honest, but I figured why bother, it's in my blood!!
Thought about it...wouldn't fit, you have a newer style bucket. And I saved myself the $$ which right now is tight!! I don't know if I'll be able to afford to finish this project!! :nunchuk1:
Old Feb 1, 2011 | 10:29 AM
  #339
jared91's Avatar
use silicon to seal that, wouldnt plastic filler or any other kinda glue eat that housing and weaken it?
Old Feb 1, 2011 | 01:16 PM
  #340
Spoolin's Avatar
GFYS and STFU
Why would plastic weld eat plastic? I think since it's not really under any pressure your right about using silicon though.
