Spoolin's attempt to Spool...
Old Jan 28, 2011 | 10:39 PM
  #321
1989k1500's Avatar
If you have disconnected the fuel line from the fuel rails on your truck you know how to take those fittings off.
Old Jan 29, 2011 | 05:13 PM
  #322
joeyc125's Avatar
11 Second Truck Club
Originally Posted by Spoolin
Anyone know if these come off?
They are the plastic nipple fittings that route coolant into the heater core, I don't want to break them but if they don't come off than I'm probably gonna have to cut them off. I wasn't planning on not running the heating system but due to fitment issues with something it's gotta go.
They use a 5/8" fuel line disconnect tool, they are usually pretty stubborn, you just have to work the tool in all the way.
Old Jan 29, 2011 | 05:49 PM
  #323
black04's Avatar
I'm about to drill a hole in the top of my fuel bucket to run the power wires and ground wires to the pumps. My questions is how would I seal that hole at the top of the bucket so that it's not leaking anything into or out of the tank.
So far I've got three things at my disposal...
JBWeld
Loctight Plastic Epoxy (2-part)
Ultra Gray RTV
What's the best to use or should I use a combination of them?
I remember seeing a connector on racetronix ill see if i can find it.
Old Jan 29, 2011 | 05:52 PM
  #324
Atomic's Avatar
I have a gauge for that
felt the same way about my ex
Old Jan 29, 2011 | 05:55 PM
  #325
black04's Avatar
You can see it in this picture. I remember seeing one with 4 wires coming out if you want to run duals.
Old Jan 29, 2011 | 05:58 PM
  #326
black04's Avatar
Found it here!
http://www.racetronix.biz/itemdesc.a...WS-001&eq=&Tp=
Old Jan 30, 2011 | 02:13 AM
  #327
Spoolin's Avatar
GFYS and STFU
Mmmm...can't say I've ever dealt with stock fuel lines and rails...that's sad isn't it? I take it it's not like the fuel line quick disconnects is it?
Kool, I take it that they sell those at Autozone and pepboys?
Originally Posted by black04
**** that would be perfect...
I'm gonna see if I can't make my retarded idea work first, if not then I'm gonna go this route! People make **** for everything now!
Thanks
Old Jan 30, 2011 | 02:14 AM
  #328
Spoolin's Avatar
GFYS and STFU
dont they have clips holding them on like the fuel lines at the pump?
Those are the quick disconnects, I felt around behind it and didn't feel any of those plastic clips. I'll look again tomorrow morning.
Old Jan 30, 2011 | 10:17 AM
  #329
1989k1500's Avatar
Yea its just a quick disconnect. You can get the tool from pretty much anywhere.
You just shove it in the backside towards yourself and when you get the tabs that line will come right off.
Old Jan 30, 2011 | 12:54 PM
  #330
Spoolin's Avatar
GFYS and STFU
Oh ok! Than yeah, I am familiar with those. Simple enough! Thanks, I'll head down and grab a 5/8" disconnect tool. Didn't even know they made those, that would certainly be easier then using screw-drivers like I usually do!!
Thanks
