Spoolin's attempt to Spool...
Old Jan 24, 2011 | 10:20 PM
  #291
Spoolin's Avatar
GFYS and STFU
Lazy *** its only 4 bolts since you dont have a hitch
You and your buddy coming to SAR?
8 bolts!!
Also, I wanna and he knows I'm down to go, but Lee's gotta check his pocket-book, he's spent a fortune on parts for his truck this month and didn't plan for plane tickets. But if he can get his together I plan on going.
Old Jan 24, 2011 | 10:24 PM
  #292
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Well get your poop in a group, there is a BBQ/Dyno Day at Nelsons the day before and after the track on Saturday a bunch of us are getting a hotel room in SA to have some fun afterwards
PS wtf-ever 8 bolts, just put a roll pan made out of 1/2" plate on it. It will keep from getting dented in when someone rear ends you again and it will aid in traction
Old Jan 24, 2011 | 10:27 PM
  #293
MikeGyver's Avatar
Originally Posted by Spoolin
... I plan on running remote leads into the bumper so as to do an easy jump start if need be. Only drawback to this is that I'll have to pull the bumper off to swap out batteries. Ahh well...
I'd put a hinged floor in the bed for access to both the battery and the tank. No I wouldn't, I would only wish that I did after replacing the fuel pump a week after replacing the battery.
Old Jan 24, 2011 | 10:44 PM
  #294
cttandy's Avatar
I say weld up a good solid brace on the frame and weld in a roll pan. That way, whenever you want to change the battery, you have to pull the cotton-pickin bed off!
LOL, looks awesome. I would leave it as is. Neither the bumper or bed is a major issue to remove when you need too.
Really, it would be really easy to hinge the whole bed if you wanted to. And it would be a neat custom touch to be able to flip the whole bed up and show off the work! Heck, you could even fill the tank directly and have no exposed tank filler with the bed down.
Old Jan 25, 2011 | 03:37 AM
  #295
Spoolin's Avatar
GFYS and STFU
Id use these instead of zip ties to hold your fuel lines
http://www.summitracing.com/parts/SUM-G1882/
Ordered!!
Thanks
Yeah, I'm really interested in going, I'll see if I can't get Lee to get up off his *** and buy a plane ticket.
If it does become a problem That's actually a pretty neat idea!!
Thanks but no thanks. If I did that I would have to get the mandatory lambo doors as well, probably get a hood that opens like a vette as well. I think I'll stick to what I got!!
Old Jan 25, 2011 | 05:25 AM
  #296
JimS's Avatar
I'd give strong consideration to putting an access hatch in the bed. Do you leave the battery in the weather or box it in?
Old Jan 25, 2011 | 08:52 AM
  #297
vicalma03's Avatar
Originally Posted by JoeyGC5
I just drilled straight across from the rearward hole. Drill and tap for an 1/8NPT and I used a 90 degree -4an to 1/8NPT fitting.
Ok so could I use the forward hole as the return?? Lets say drill and tap for a 1/2 line?? Thanks for the info and thats a really nice crossmember/battery tray.
Old Jan 25, 2011 | 09:18 AM
  #298
1slow01Z71's Avatar
Hope you ordered the right size, I just posted the first ones I found and didnt even look at the size
Old Jan 25, 2011 | 09:37 AM
  #299
1989k1500's Avatar
Well now you owe him 9 dollars.
Old Jan 25, 2011 | 10:44 AM
  #300
1slow01Z71's Avatar
Well if he comes down here for the track meet Ill buy him his first Texas beer and show him a good time
