Slow and getting slower
Old Aug 16, 2012 | 11:18 PM
  #1171
Atomic's Avatar
I have a gauge for that
done
Old Aug 16, 2012 | 11:25 PM
  #1172
oakley6575's Avatar
Nice work Atomic! Interested to see how the intake eats all that boost. Should kick ***
Old Aug 17, 2012 | 02:02 PM
  #1173
Spoolin's Avatar
GFYS and STFU
Just out of curiosity, why did you swap intakes? That intake wasn't really ballooning was it?
Don't put the FPR under the intake, it looks clean but it's a total PITA if you want to remove the fuel system or change the fuel pressure.
Old Aug 17, 2012 | 02:10 PM
  #1174
Atomic's Avatar
The center would flex some but it was never an issue...I really just wanted something that looked cool
Old Aug 17, 2012 | 02:22 PM
  #1175
TTownTech's Avatar
Expecting any drastic power gains??
Old Aug 17, 2012 | 02:23 PM
  #1176
chevyboy.520's Avatar
Weak! Jk looks mean! I really like the way it turned out in black! Now let's see some new dyno numbers, and some 1/4 times!
Old Aug 17, 2012 | 02:29 PM
  #1177
TX Tahoe Z71's Avatar
Wowzers! Looks good in there, eager for results.
Old Aug 17, 2012 | 03:27 PM
  #1178
Atomic's Avatar
I really dont know as far as gains....hopefully a pretty good bit at high rpm with the intake, and the larger cold side should help out some. This 3.5" is a lot tougher to fit...im going to have to move the pcm over or down some so the pipe isnt wedged between the radiator hose and the pcm cover. Also need to trim the fan shroud by the driver side fan so the pipe can sit closer to the front. Combination of a bigger pipe and the throttle body being pushed a few inches forward make this a lot more difficult, but I almost have it!
Pretty substantial size difference
Had Rick make me this, dual bov's always look so much meaner.
Old Aug 17, 2012 | 04:23 PM
  #1179
JDon99's Avatar
Looks good! Where is the upper radiator hose going to end up?
Old Aug 17, 2012 | 07:31 PM
  #1180
custm2500's Avatar
Ph.D. in HUBRIS
Looks like final product material to me!!!! hahaha
