Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old Sep 16, 2007 | 07:51 PM
  #1821
moregrip's Avatar
what a rush!
Originally Posted by 2004SSS
question grip, how do you pull the iw crank pulley if you need to? and two this is a general question but can you lock the crank in place by locking the converter manually with hpt to remove the crank bolt without having the engine turnover?
To remove the IW crank damper, you would remove 2 or 3 of the inner cap screws and use a traditonal damper puller to remove the pulley. (ends up being easier to install and remove as you are dealing with threads vs. claws)
it would look something like this:
I have a kent-moore flywheel holding tool to keep the crank from turning.
Old Sep 16, 2007 | 08:23 PM
  #1822
moregrip's Avatar
what a rush!
last pics of the day,
after some re-arranging, looks like I figured out how to go about mounting the Canton inter-cooler reservoir. couple of things to note: one, it's bigger than it looks, two, it will still fit just fine (albeit with a little more fab work than I originally thought) but it seems to fit the engine bay nicely none-the-less:
Old Sep 16, 2007 | 08:55 PM
  #1823
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Hmmm That would make a nice meth can...
Old Sep 16, 2007 | 08:56 PM
  #1824
moregrip's Avatar
what a rush!
ran me $154 shipped
Old Sep 16, 2007 | 09:03 PM
  #1825
Stoichiometric's Avatar
That is a nice tank, fits well with everything under the hood. What is the capacity?
Old Sep 16, 2007 | 09:07 PM
  #1826
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Time to break out the polishing compound
Old Sep 16, 2007 | 09:09 PM
  #1827
moregrip's Avatar
what a rush!
no idea, I looked on Canton's website but I don't remember it saying what it held.........I'd guess at least a gallon
Old Sep 16, 2007 | 09:10 PM
  #1828
moregrip's Avatar
what a rush!
ok jackass
Old Sep 16, 2007 | 09:30 PM
  #1829
1slow01Z71's Avatar
It might give the engine bay enough bling shine to overpower the stock valve covers.
Im just giving you **** because Im jealous, I dont have the time nor the patience to undertake a badass project like yours, my hat is off to you.
Old Sep 16, 2007 | 10:52 PM
  #1830
2004SSS's Avatar
the kent moore tool is that the one that you put in place of the starter? i just want something where i dont have to remove that. just wondering if that idea would work?
