Project "Blown HD" my 6/8 drop/shortblock/heads/cam/blower/tranny install
Old Sep 16, 2007 | 12:04 PM
  #1801
Runwhatchabrung's Avatar
Originally Posted by moregrip
I had to measure all the bolts and order them individually
maybe you might be able to help. I had someone pull my motor and trans and was supposed to get work done yada yada well needless to say they fell of the face of the earth with my parts and im left to buy new **** and try to get it all back together. By any freak chance yo wouldnt happen to have a list of some sort of the acessories bolt sizes and quantities do you?
Old Sep 16, 2007 | 02:05 PM
  #1802
moregrip's Avatar
what a rush!
do you have a Magnacharger Radix setup?
Old Sep 16, 2007 | 02:06 PM
  #1803
nope didn't you do your stock acessories bolts too? Couldnt tell with so much bling going on there.
Old Sep 16, 2007 | 02:08 PM
  #1804
moregrip's Avatar
what a rush!
yes I have some, what do you need?
Old Sep 16, 2007 | 02:18 PM
  #1805
ZZebes's Avatar
Whats the part number on the balancer Bolt???
Old Sep 16, 2007 | 02:34 PM
  #1806
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Me too
But they are coming out with an engine kit SOON so Im told.
Old Sep 16, 2007 | 03:05 PM
  #1807
moregrip's Avatar
what a rush!
the one I'm running with the oversize IW crank damper?
Old Sep 16, 2007 | 03:13 PM
  #1808
moregrip's Avatar
what a rush!
Old Sep 16, 2007 | 03:17 PM
  #1809
moregrip's Avatar
what a rush!
I started out today like I do most "parts hunting" days not expecting a whole lot......LOL............wouldn't you know it, NAPA is good for something every once in a while
First good find of the day was this pre-formed coolant hose to run from rear H/E to front H/E:
as you can see it worked out perfectly(just need to remember to write the part# down)
Old Sep 16, 2007 | 03:23 PM
  #1810
moregrip's Avatar
what a rush!
second good find of the day was the correct length 8-Rib Serpentine belt(first one was too short) without having to special order it I was completely blown away on this one, it's not a normal stocking #, they just happen to have one in stock
****, I'll take a win/win everytime, thank you sir can I have another!
here are some good angles so you can FINALLY see what a Magnuson Radix 8 Rib drive pulley arrangement looks like:
glad to finally wrap this project up
Good news is, if you want to run the same setup I have all the info/part #'s you'll need to make it work without having to trial and error it, or piece it together like I did.
