Project 50 Shades LSXAP Shoptruck
Old Feb 18, 2016 | 10:47 PM
  #261
George C....'s Avatar
Formerly ScreamingL
Originally Posted by Atomic
Mine warped pretty bad after a lot of use...had to use a hammer to get it off since it was jammed between two of the studs.
You built yours right?
Old Feb 19, 2016 | 08:26 AM
  #262
Atomic's Avatar
I have a gauge for that
No, my log started off life as a kb part, then heavily modified, then ditched for a truck manifold.
Yea warped out of the box I would be a little pissed.
Old Feb 20, 2016 | 09:38 PM
  #263
lsxperformance's Avatar
I was able to get all the bolts in on the turbo flange. And it pulled up if you go little by little.. In a cris-cross pattern. I really don't like it but I'm gonna give it a whirl. I welded the bungs in the valvecovers for the catch cans 2, -10 an bungs. My custom turbo cam showed up and I installed that, checked preload on the lifters, and put all new gaskets on it. I'm excited and wanna drop it in.
I have a few questions:
What dipstick and tube configuration should I use?
My current nitrous setup is a nozzle where you guys think I should put it? Or ditch it for a plate?
The holes on the pan above the oil filter which one is pressure? I'll plug the other one not used..
Old Feb 25, 2016 | 12:58 AM
  #264
A cheap steam vent setup I made turned out alright. I need to paint the blue one.. Kinda stands out.. Had about 60$ in the setup maybe less.
Old Feb 25, 2016 | 12:59 AM
  #265
And a pic from behind
Old Feb 25, 2016 | 09:57 AM
  #266
Vortec350ss's Avatar
Looks good. what did you use?
Old Feb 25, 2016 | 06:01 PM
  #267
I made it out of 1/4" brake line, and at the front I converted it to an -6 and connected the two banks with push lock hose I like it I use it on all kinds of things.
Old Feb 25, 2016 | 10:07 PM
  #268
I did some mock up, been fitting the oil lines and drains, and the dual gates
Old Feb 28, 2016 | 02:30 PM
  #269
SCChevy's Avatar
I love this! Really hope this little junkyard 4.8 makes some real power for you.
Old Feb 29, 2016 | 01:46 PM
  #270
Me too should be interesting. Hopefully it keeps the rods in the block for a while.. I've been so busy here at the shop. I took on a gem 5 Camaro project as well here I bought as a roller and plan to flip it when done on top of all my day-day work. It's a 13 1LE Camaro I bought has 8500 miles on it.
