Project 50 Shades LSXAP Shoptruck
Old Nov 8, 2015 | 10:05 PM
  #221
1FastBrick's Avatar
Custm2500's Rude Friend
slap a running motor in it just so it moves.
Pull the 408 and do what you described on it. I would replace the mahle with a different brand. I don't think they are intended for what you're doing with them.
You may want to consider having tops of the new pistons coated as well.
Old Nov 8, 2015 | 11:18 PM
  #222
lsxperformance's Avatar
Ya that's why I was gonna do it as well as possibly switch to a beefier Carrillo billet rod. It just has compstars in it most likely be ok. Will go as far as the block can, I've also considered pulling the tfs heads and drop ls3 heads on the 408 with a new piston. And play and start a dart motor build for the compound boost setup. I just think it's gonna lift heads a lot if I proceed with the lq4 block.
Old Nov 28, 2015 | 10:28 PM
  #223
blitzin247's Avatar
Originally Posted by lsxperformance
Most of the work was done in the snout.. This was done to help drop IAT's also opened it up enough to port match a nw 102 t body this I'm told has been a gain of 100+ wheel don't quote me on that I haven't done any research or side by side comparisons to back that... The lower manifold from what I can tell matches very nice to the ports and really doesn't look to be much if any gain from doing the lower manifold. So it was left alone. I need to look closer at the Lower manifold I ordered the bolts to mount the blower to the heads yesterday, as well as the steam vent lines because the oe unit from the truck won't fit.. Also a 07+ gm truck waterpump is required to clear the discharge actuator.. ***Also a heads up*** the actuator if your blower did not come with one... New ones can be purchased from gm, there is a special tool that comes with gm actuator in the box that will help you set the actuator correctly.
I was just reading through your build from day one. I am seriously contemplating a 5.3 lsa build. Is the 100hp in addition to the 100-150hp that the lsa adds? Sorry if you have already answered this question, and I havent seen it yet.
Old Nov 30, 2015 | 07:20 PM
  #224
I dunno I haven't done back to back testing. Seems pretty generous to me. Honestly don't have an answer, just what I was told.
Well finally have some parts coming in soon here's a couple pics. I've been waiting on my turbo, and hot side since February 2015. It features sinister Racecraft crossover and log manifold with dual 44mm gates, s488etr-ho with a v2 racecover and I went with the 96mm exhaust, and 1.58ar exhaust housing. I've decided to pull the heads and have Frankenstein fix and do a different Cnc program on em. I'll probly drop a new piston in or possibly get a set of wiseco pistons in. Also I'll switch to an inconnel exhaust valve at the same time.
Old Nov 30, 2015 | 07:22 PM
  #225
And here's the turbo.. Mines on the left
Old Nov 30, 2015 | 07:24 PM
  #226
Again on the left
Old Nov 30, 2015 | 07:36 PM
  #227
GMCtrk's Avatar
Baller turbo! Me want
I wonder how different downpipe position is with the 1.58 housing vs 1.32
Old Nov 30, 2015 | 08:04 PM
  #228
I may make two of them.. We will see depends how much I race. I'm limited to a 4"dp and keep ac. But I may cut my stock hood for a hood exit for racing 5" they said it really cuts down on power output running 4" but I'll try it and see what it does.
Old Nov 30, 2015 | 10:02 PM
  #229
Atomic's Avatar
I have a gauge for that
Nah you wont notice any power difference with 4" vs 5". 5" will spool a little better though. Are you still planning on doing the compound setup? If so I would have gone to a bigger turbo...
Old Nov 30, 2015 | 10:07 PM
  #230
GMCtrk's Avatar
That turbo should be capable of 1250-1300 rwhp...How much more you need??
