Pearl's rcsb awd turbo build!
Old May 25, 2014 | 08:40 PM
  #151
Mortiz's Avatar
Formerly PurplePearl (2014-04-06)
Old May 25, 2014 | 09:00 PM
  #152
_zebra's Avatar
makes children cry
and take them stickers off the tires before you drive it, or there'll be remnants of them until the tread wears down.
Old May 25, 2014 | 09:38 PM
  #153
Mortiz's Avatar
still along ways from driving it
Old May 26, 2014 | 01:11 AM
  #154
_zebra's Avatar
makes children cry
i know how you feel - right after college, i broke a rod in the old 4.3. having only temporary on-call work, it took 5 months between saving up the $$ and installing parts to simply get a new engine running in my only vehicle.
it'll come around soon enough!!
Old May 26, 2014 | 10:11 AM
  #155
1FastBrick's Avatar
Custm2500's Rude Friend
Nice to see the body sitting on the frame.
What will it take to get the bed on there?
Old May 26, 2014 | 01:15 PM
  #156
Mortiz's Avatar
Alot of beer... Thinking about starting it next week
Old May 28, 2014 | 09:26 PM
  #157
Mortiz's Avatar
Here is what I plan on my fuel system.
e85
160lb bosch injectors
walbro 450 in tank
a1000 on a rear sump
10an feed
8an return
aero boost regulator
Might be a little over kill but it will get me more than i need!
Old May 28, 2014 | 10:34 PM
  #158
Atomic's Avatar
I have a gauge for that
Might not be enough actually...are you running the 450 and a1000 in parallel or the 450 feeding the sump or what?
Old May 29, 2014 | 10:07 AM
  #159
Mortiz's Avatar
Running it in parallel with a hobbs switch.
Old May 29, 2014 | 11:07 AM
  #160
Atomic's Avatar
In terms of injector matching, even with those 2 in parallel you are pump limited. 160s are huge injectors compared to the pumps.
at 20psi of boost with a 60psi base pressure (stock)
160s flow 771 l/hr
450+a1000 flow 712 l/hr
Which means you will actually drop fuel pressure above about 12psi of boost. Not really a big deal, because even with the pumps max output at 20psi of boost you have enough fuel for about 1150rwhp on the corn. Your injectors max (at 95% idc) around 1250rwhp on the corn.
The matching looks worse on gas, about 150rwhp difference between injector capacity (1770rwhp) and pump capacity (1620rwhp).
