Oakley's History Lesson and Build Thread
#202
How do you select a different map sensor?
Edit: I think I figured it out. Even though the histogram shows 30kpa-320kpa, in the histo settings it showed the MAP plot points to be 20-105kpa. So I changed them to 3 bar values and I will give it a whirl tomorrow. Can't wait to see how much boost I'm making at the moment. The truck really felt good in boost
If you aren't logging it in. the primary table, it won't show up on your guages, charts, or histogram
#203
good deal, on your primary table when you right click to insert, then you choose the sensor or pid. I had the same problem with the scanner not plotting the right values with the correct kpa.
So I thought this truck would be making close to 8-10 psi after how it felt last night. I got my scanner straitened out and it is only making 5.5psi
It feels like it is already making alot more hp than my 408 did! I'm super happy with how it is running. Just need to get the tune straitened out. Right now i'm running 12-13 degrees in boost. How much more spark do you guys think it can handle?
#204
Here is a pull to 70mph on 5.5psi. Next weekend I will get the boost controller hooked up and up it to 8-10psi. It takes about 3800-4000rpm before it screams. Sorry for the shitty vid. My GoPro wouldn't turn on..wtf
http://www.youtube.com/watch?v=gJAFdyNHI5o
#209
Had the same wideband before and it would never show up in my vids either, always just looked like it was blinking.
Truck sounds awesome....and I forgot how much I love your gauge setup...
#210
