Oakley's History Lesson and Build Thread
Old Nov 3, 2013 | 03:39 AM
  #201
TIM Z's Avatar
11 sec. Truck Mod
Truck is looking good under the hood ! Lol
Good luck with your tuning , glad ya got her running , nice work .
Old Nov 3, 2013 | 05:47 AM
  #202
Chevy_King1500's Avatar
How do you select a different map sensor?
Edit: I think I figured it out. Even though the histogram shows 30kpa-320kpa, in the histo settings it showed the MAP plot points to be 20-105kpa. So I changed them to 3 bar values and I will give it a whirl tomorrow. Can't wait to see how much boost I'm making at the moment. The truck really felt good in boost
good deal, on your primary table when you right click to insert, then you choose the sensor or pid. I had the same problem with the scanner not plotting the right values with the correct kpa.
If you aren't logging it in. the primary table, it won't show up on your guages, charts, or histogram
Old Nov 3, 2013 | 10:13 AM
  #203
oakley6575's Avatar
Thanks bud. After driving this truck, I'm kind of jealous of the 600rwtq you have in the low rpm
I figured it out just now. I didn't change the Manifold Absolute pressure pid to the 3 bar one. Now I'm seeing values above 105kpa
So I thought this truck would be making close to 8-10 psi after how it felt last night. I got my scanner straitened out and it is only making 5.5psi It feels like it is already making alot more hp than my 408 did! I'm super happy with how it is running. Just need to get the tune straitened out. Right now i'm running 12-13 degrees in boost. How much more spark do you guys think it can handle?
Old Nov 3, 2013 | 05:35 PM
  #204
oakley6575's Avatar
Here is a pull to 70mph on 5.5psi. Next weekend I will get the boost controller hooked up and up it to 8-10psi. It takes about 3800-4000rpm before it screams. Sorry for the shitty vid. My GoPro wouldn't turn on..wtf
http://www.youtube.com/watch?v=gJAFdyNHI5o
Old Nov 3, 2013 | 05:52 PM
  #205
TIM Z's Avatar
11 sec. Truck Mod
She seems to run good and sounds good.
Is your wideband working?
Old Nov 3, 2013 | 06:05 PM
  #206
oakley6575's Avatar
The wideband is working fine. It reads lambda
Old Nov 3, 2013 | 07:01 PM
  #207
TIM Z's Avatar
11 sec. Truck Mod
Roger that , hard to see on this old IPhone 4S lol
Old Nov 3, 2013 | 07:09 PM
  #208
oakley6575's Avatar
Oh I see what you mean now. It looks like it is blinking or something. Just from recording on the good old iPhone.
Old Nov 3, 2013 | 08:53 PM
  #209
ak2007r6's Avatar
Had the same wideband before and it would never show up in my vids either, always just looked like it was blinking.
Truck sounds awesome....and I forgot how much I love your gauge setup...
Old Nov 6, 2013 | 02:01 PM
  #210
oakley6575's Avatar
Thanks bud. Just took a vid with the go pro and the wideband does the same thing
