Oakley's History Lesson and Build Thread
Old Nov 6, 2013 | 02:10 PM
  #211
oakley6575's Avatar
I need some advice from you turbo guys. How are you controlling spark? Currently I have the high and low octane tables table topped at 26 degrees in the boosted regions. Then I'm using the AFR correction to pull timing when it it commands anything richer than 13:1 or so. The problem in seeing is that there is about a one second delay from the time it sees boost to the time boost enrichment is commanded. So it builds almost 5psi before timing drops from 26 degrees to 14. So in that second, I'm picking up knock retard.
At first I was just setting the main spark tables to 12-14 degrees of timing in the boosted region and not using the AFR correction at all. It would just fall on its face though before the turbo spooled.
So back to the original question, how are you boosted turbo guys pulling timing?
Old Nov 6, 2013 | 02:27 PM
  #212
Atomic's Avatar
I have a gauge for that
Make sure you have the PE enable thing maxed out, so there isnt a delay.
I just have the last row on the timing table set to what I want WOT timing to be, cant really adjust it with boost on the 99-07 pcms. That table is maxed out pretty early.
And as far as the gauges not showing up, that is due to the refresh rate of the gauge being below the frame rate of the video recorder.
Old Nov 6, 2013 | 02:36 PM
  #213
oakley6575's Avatar
Yea I'm only making about 1.10 g/cyl right now. I do have the PE enable maxed out and there isn't a delay in PE. The delay happens between PE and BE. It will command .87 lambda in PE and then once it starts building boost, it stays in PE for about a second before it commands .78 lambda which is what I have my BE set to.
Richard, do you use BE or only PE?
Old Nov 6, 2013 | 03:10 PM
  #214
Atomic's Avatar
I use both and dont see a delay...
Old Nov 6, 2013 | 03:12 PM
  #215
oakley6575's Avatar
WTF. I have my BE triggered at 105kpa. But it doesn't command it until about 130kpa.... It's pissing me off
Old Nov 6, 2013 | 03:21 PM
  #216
Atomic's Avatar
I dont have mine come on until 125kpa I think...you dont need pig rich with just 1psi.
Old Nov 6, 2013 | 03:37 PM
  #217
Chevy_King1500's Avatar
you could just set your PE to something like 12.5 AFR, Kpa to 85 and work with the throttle %
Old Nov 6, 2013 | 08:22 PM
  #218
oakley6575's Avatar
It is set up like that. I have PE coming on anytime 85kpa is hit. I'm just having a hard time getting spark to drop correctly because of the delay in BE. I will just have to use the primary spark tables instead of the AFR correction tables.
Old Nov 9, 2013 | 06:44 PM
  #219
oakley6575's Avatar
Truck is running pretty damn good. I thought I blew it up today and it was a good wake up call . I got the boost controller hooked up and turned it up from 5.5psi to 7psi, then to 9psi, then to 12psi.. I picked up some really good knock retard during the 12psi run and thought it let go around 6000rpm. Luckily no harm was done and it still runs and pulls clean. I changed the tune and lowered it to 9psi and it is super fun.
First problem arose today after beating on it for a while. There is a pinhole in one of my heater hoses. Don't know if I did it when installing it or what happened. So I have a pretty good coolant leak I will have to fix before I can drive it anymore. Anyways, my uncle recorded an 8-9psi pull through first gear. Can't wait to get a muffler on this truck and drive the **** out of it.
Old Nov 21, 2013 | 03:09 PM
  #220
B_E_A_S_T's Avatar
Here is basically how the truck sits now
Engine:
Lq4 iron block 408
Callies Compstart crank/rods
Wiseco pistons
231/239 114+2
STOCK LS3 heads and intake
Drivetrain:
Built 4l80e
Trucool 40K
B&M Megatruck shifter
Auburn Posi
3.42 gears
Exhaust:
dual 3" into a 22" magnaflow
single 4" out over the axle
Fuel:
STOCK fuel pump (don't know how that is holding up)
-6an feed to Aeromotive fpr
-6an return
42lb LS3 injectors
91 octane pump gas
Suspension:
Belltech 3/5 drop; springs, hangers, shackels
McGaughys c-notch
Real nice build! You did some great work!
What front bumper cover do you have on in this pic?
