LQ4 out 5.3 Turbo In (Trials and Tribulations)
Old Oct 17, 2018 | 11:58 AM
  #21
RA62025's Avatar
Banned
Drilled and Tapped for the oil feed. Used 1/4" drill bit all the way in then 25/64 bit for the fitting and then 7/16-20 tap.
Block came
Mmm Forged Pistons and H Beam Forged Rods also has a new Z06 Crank all balanced with in 1 gram
Milled .020 off my LQ4 317 Heads
Stuck the Heads on just for some pictures
.660 Dual BTR Valve Springs
Old Oct 17, 2018 | 03:40 PM
  #22
RA62025's Avatar
Banned
After cleaning up the top end I saw this little gem. I guess the guy also did some drilling into the throttle body. This makes me think that he never tuned the truck after the cam was install.
Old Oct 19, 2018 | 12:40 PM
  #23
Alex in Houston's Avatar
Default Everything is either a blessing or a lesson
If you play in the car mod game long enough - you’ll get screwed one day. It happens to ALL of us at some
point. But damn, after all the **** you’ve been through with that truck - you should be done with bad car karma for life.
Old Oct 19, 2018 | 12:56 PM
  #24
RA62025's Avatar
Banned
I hope so. I have learned a lot though which is good.
Old Oct 19, 2018 | 01:01 PM
  #25
RA62025's Avatar
Banned
Put lifters into the trays making sure the roller of the lifters are facing the correct way so they spin on the cam. Then place the tray in while it's holding all four lifters
Make sure the words "Front" are facing towards the front of the engine or timing cover
Oil Pan on. Make sure you follow torquing specs in order for no leaks. I put black RTV on all 4 corners of the block before the oil pan gasket and the pan.
Picture of my fitting I had welded on. Will this be ok and above the oil level? I've seen others put there's here.
Old Oct 23, 2018 | 11:03 AM
  #26
RA62025's Avatar
Banned
74mm Precision Turbo with T4 Flange
Huron Speed Log. Is that smaller pipe sticking out from the front bottom where the waste gate goes? I'm really smart.
When you have had such bad luck you have trust issues.
Old Oct 23, 2018 | 12:36 PM
  #27
1FastBrick's Avatar
Custm2500's Rude Friend
FYI, you need to support it toward the front of the pan from underneath.
Old Oct 23, 2018 | 12:51 PM
  #28
RA62025's Avatar
Banned
Yeah my jack isn't tall enough to do that I tried. I can move the chain of the cherry picker to the most frontal point though. Right now the cherry picker and stand are taking most of the weight.
Old Oct 23, 2018 | 01:18 PM
  #29
1FastBrick's Avatar
I have often wondered why they didnt put more angle in those stands to account for the sag and some of the slop with the tube fitment.
Old Oct 23, 2018 | 01:23 PM
  #30
RA62025's Avatar
Banned
Originally Posted by 1fastbrick
i have often wondered why they didnt put more angle in those stands to account for the sag and some of the slop with the tube fitment.
what do you think about my wastegate comment?
