ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods
Old Feb 15, 2018 | 02:20 PM
  #71
97_ek's Avatar
Originally Posted by black04
Do the 2014+ wheels still tuck like the nnbs wheels? Looks like they stick out more.
I have these exact wheels on my 03 Sierra with a 2/4 drop. They do fine until I put a load in it, but then fenders did rub the side of the tire a little when loaded. You could roll the fenders and be fine. I just ground my fender lips back a little bit, and it will tuck now with no issues.
Old Feb 15, 2018 | 03:15 PM
  #72
Jeebalow's Avatar
Originally Posted by Atomic
You want it slightly offset so the ujoint cap velocity is not zero, but its generally <1degree. If its dead on perfectly aligned the cap doesnt rotate and doesnt get lubricated properly.
As long as the pinion angle doesnt match the driveshaft angle (from a side view, not a plan view), this should be a non issue. The rear end is likely just not centered properly due to tolerances. It should be ok to center it up.
Per the spicer driveshaft install manual, you want somewhere between 1 and 3 degrees. Like you said, never 0. It shouldn't matter which plane this angle is in. AFAIK.
Old Feb 15, 2018 | 03:33 PM
  #73
Atomic's Avatar
I have a gauge for that
Yea misalignment plane wont matter, but when the rear gets lowered in that 4-6" range it gets awfully close to perfectly aligned. This is really more academic than anything since it mainly applies to heavy machinery that doesn't articulate, but thought it was worth mentioning. Normally suspension cycling you get when driving should be fine.
Old Feb 17, 2018 | 11:21 AM
  #74
terravast4's Avatar
Originally Posted by ILuvJDM
VAS low profile version for flip kits
do you have a contact for VAS? I tried emailing them from the facebook email and get no response.
Old Feb 17, 2018 | 04:59 PM
  #75
ILuvJDM's Avatar
Both of my transactions were done through facebook messenger, then they sent an invoice, sorry
Got the rear finished today, I'm worn out
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-gbnskgd.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-ulym7fg.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-p1r6mfx.jpg
Added some protection to the brake line that goes over the notch
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-mwvhep5.jpg
Rubbing the brake line on the bottom of the bed, but I have a stainless line to replace it and hopefully route it better
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-flshyhy.jpg
I moved the axle over as far as possible. I got them even at full droop of the axle, but once you put the weight on the axle, it kicks over 1/2"
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-xdait9z.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-rpc6vl1.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-sjo5bez.jpg
Cleaned up the wheels before installing them
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-iremhxv.jpg
Then turned the truck around again to finish the last few items on my list before being able to drive it
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-mnbqlow.jpg
Still settling
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-v4e68vu.jpg
Old Feb 18, 2018 | 10:32 AM
  #76
terravast4's Avatar
notch looks badass. great work
  #77
terravast4's Avatar
thats a 5" drop up front?
Old Feb 18, 2018 | 11:07 AM
  #78
ILuvJDM's Avatar
thanks, I'm not too sure on the drop, but the truck is lower than I want in the front right now. I'm shooting for 15.0" front height which is around 4.5" front drop. I try to keep the fender gap the same front to back
Old Feb 18, 2018 | 01:07 PM
  #79
hutch311's Avatar
Great looking truck! Appreciate the good pictures and documentation of the build. Keep up the good work.
Old Feb 20, 2018 | 08:32 PM
  #80
ILuvJDM's Avatar
Thanks, I'll try to keep it interesting and not let it stall out...
Got some of the small, final items done today, which are the hardest things on a project
Brass fitting that came with the kit vs the aeroquip pushlock fitting. Went with a 45 angle to -10AN and then a -10AN to 3/8npt so I could reuse the hole I already tapped
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-4bz1oud.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-x4wnmsy.jpg
It was too hard to get to the bolts for the drain fitting, so I just left this one alone. It's a vertical fitting on a gravity drain, so I don't see that barb fitting ever leaking...
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-ibgymha.jpg
Added some locking nuts to my coilover mounts. They were leftover from my c-notch hardware
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-ylzfrz8.jpg
I bought some super expensive fire sleeve for the AC line, but it doesn't fit the curves of the line, so that was a waste of $80. Decided to just use DEI cool tape. Not too happy with the look, but it should keep the line from bursting
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-rh6qita.jpg
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-yojqsb3.jpg
Also got both fender liners installed, tightened the clamp for the crossover where there was a small exhaust leak, added the safety washers for the heim tie rod ends, adjusted the ride height of the coilovers, cleaned the front wheels and torqued them down.
