ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods
#51
I considered doing that, and I may have to when I switch to AN fittings, but for now I got it to work with the couplers and stuff. You understand how odd it is though that you have to leave a bolt out of something just to get it to work in a normal application... Little things that annoy me
You could always get an AN to push loc fitting to go on what I have listed below.
Not the exact fitting you need, but you get the idea.
https://www.maperformance.com/products/billet-turbo-oil-drain-flange-universal-t6-and-borg-warner-s400-by-torque-solution?variant=5343211011&gclid=Cj0KCQiAzMDTBRDD ARIsABX4AWzhos-PfpTCHN4tg6P1Dw6jRFJaKWfSZmbMYyCt5aeUjZ4f7lHKd6EaA r1YEALw_wcB
https://www.summitracing.com/parts/icb-an816-1008xl?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-ict-billet&gclid=Cj0KCQiAzMDTBRDDARIsABX4AWxu6Yxa3B--aJtYPry3c1NN7a0ACzpNZ84a72dw3jm9GS5JYq8YosIaAqxgEA Lw_wcB
#52
Oh I completely understand man, lol trust me.
Finally tackled the three piece engine covers. Had to modify the drivers side to fit the 0ga power wire coming off the alternator
Just added a nice smooth opening using a dremel, looks like the factory openings
What I had to do to the passenger side to clear the turbo
Just need to bodywork and paint with the 2k satin black I got
#53
Got the rear disassmbled yesterday after work. Removed the spare tire and hitch. I noticed the drivers side front leaf bolt was already replaced with a shorter bolt, so I was able to easily drop both springs
Since both leafs are out, I went ahead and ordered some energy suspension poly bushings and brand new u-bolts. I'll do some cleanup and paint on the springs while they're out and also prep them for the traction bars but cutting overload and the front clamp
#54
If you are using Caltracs they have a low profile kit for flipped trucks without the overload. Mine almost fit! Just a little fine tuning.... I am going to use my rear coilovers to fine tune ride height.
#55
I was looking at the truck and trying to decide what the previous owner might have done to it. Check these out and let me know what you think it could be from?
Three marks on axle. I was thinking flip kit, but it would be two marks, right?
Odd hole drilled in rear fender looking towards front of truck in picture
Are the parking brake brackets bolted on from the factory?
I prepped for my poly bushing install and pressed out the shackle bushings
I was going to do the leafe springs, but I was caught off guard by this. The rust had broken the head of the rivet off that holds the clamp tight. Should I use these leafs and just put one of those clamps people use to stop axle wrap on there for safety?
Got tired of having to dance around all this **** in my garage, so it's all going to the dump tomorrow
#58
#59
#60
