ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods
Old Oct 21, 2019 | 02:30 PM
  #521
arthursc2's Avatar
Oh man thats rough! My poly torque axis mount lasted a trip to the store. The car actually felt better with no mount in the front than it did with the poly mount. It was bad.
Old Oct 21, 2019 | 02:38 PM
  #522
black04's Avatar
The mounts are different between 2wd and 4wd on GMT800 trucks. 2wd had one stud and 4wd has two.
Old Nov 24, 2019 | 11:02 AM
  #523
stroker87's Avatar
i just lowered my truck and its to low i like the height of your truck and wanted to know can you tell me the distance from the center hub to fender front and rear on yours?
Old Nov 24, 2019 | 03:11 PM
  #524
ILuvJDM's Avatar
15.0" all four corners
Old Nov 24, 2019 | 03:20 PM
  #525
stroker87's Avatar
awesome thanks for quick response!
Old Dec 27, 2019 | 06:39 PM
  #526
ILuvJDM's Avatar
Here are my driveline angles on the truck. I'm trying to determine the operating angles of the u joints. Am I correct that I add both angles together to get the operating angles in the drawing below?
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-0hpsabx.jpg
So I would have 4.60° rear operating angle and 8.35° front?
Rear Diff:
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-8vd3prv.jpg
Rear U-Joint
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-praie1i.jpg
Front U-Joint
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-qfwpsgs.jpg
Tranny
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-et6xmyu.jpg
Old Dec 27, 2019 | 08:00 PM
  #527
ls6454's Avatar
Oh No.... Angles......
Get ready for every possible answer in the world......
Larry
Old Dec 27, 2019 | 08:14 PM
  #528
Jeebalow's Avatar
Rear Diff:
Rear U-Joint
Front U-Joint
Tranny
Based on the direction the gauge says it is reading for each angle, you are correct.
An easy way to take the human error out of it is to put it on the diff, press the zero button (it will now read 0°), now put it on the driveshaft and it will find the difference (operating angle) between the two.
Old Dec 27, 2019 | 08:19 PM
  #529
ILuvJDM's Avatar
Man, that's brilliant, I can't believe I didn't think of that. I just zeroed it out on a level to make sure it was reading accurately and that never crossed my mind...
For now I'm going to shim the trans mount and then remeasure until I get them equal or within 1°
Old Dec 27, 2019 | 09:34 PM
  #530
stroker87's Avatar
i think up to 3* difference is acceptable, last truck i had a drive line vibration had to shim the diff and trans to get rid of it and i want to say i got it to 2* difference and got rid of it
cool vid click below
Driveshaft Angle
