ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods
Old Jan 19, 2018 | 07:26 PM
  #31
ILuvJDM's Avatar
Originally Posted by black04
Looks awesome is that the polished version? 20s or 22s? Not much you can do about the wheel rub it's pretty common with bigger wheels. I'd just be mindful when turning.
These are 20x9 with the polished finish. I bought them for my daily driver, so I got 20s. Had I known they would end up on this truck, I would get 22s
Old Jan 19, 2018 | 07:46 PM
  #32
SDjeff619's Avatar
That wheel, brake and color combination looks sick.
as for the rubbing I would try a five or 10 mm spacer on the wheel. it should clear and make the wheel and tire fitment look a little better on the outside of the fender
Old Jan 19, 2018 | 08:03 PM
  #33
ILuvJDM's Avatar
I may put some washers in there to see how it fits and if it indeed works to clear the LCA, then order an appropriate spacer off those measurements. Thanks for the idea
Old Jan 19, 2018 | 08:42 PM
  #34
milesp07's Avatar
I welded in some stops on my ridetech arms... it worked out great. I made them out of 3/8 plate and welded them to the back of the arm behind the ball joint.. Truck looks awesome btw! Any plans for the rear suspension?
Old Jan 19, 2018 | 09:21 PM
  #35
ILuvJDM's Avatar
Originally Posted by milesp07
I welding in some stops on my ridetech arms... it worked out great. I made them out of 3/8 plate and welded them on. The back of the arm behind the ball joint.. Truck looks awesome btw! Any plans for the rear suspension?
rear will be flip kit, c notch and eventually a shock relocation kit so they're both vertical behind the axle
Old Jan 19, 2018 | 10:47 PM
  #36
black04's Avatar
Do you have a part number or what size fitting was used for the coolant petcock drain? That's a great idea!
Old Jan 20, 2018 | 01:10 AM
  #37
ILuvJDM's Avatar
It's from Jegs actually - billet aluminum. It's a nice piece. I cannot remember what size it is, but I think 1.5"?
http://www.jegs.com/p/JEGS-Performance-Products/JEGS-Inline-Radiator-Hose-Drain/1206363/10002/-1
It's not really shown, but I reversed the lower hose orientation so the long straight leg was at the radiator. That allowed me to put it in that perfect spot. Went to a junkyard and grabbed some oem clamps for a clean look
Old Jan 20, 2018 | 09:24 AM
  #38
Vortec350ss's Avatar
Man this truck is clean!!!
Can't wait to see it running!
Old Jan 21, 2018 | 04:04 AM
  #39
Jeebalow's Avatar
Subscribed! Amazing attention to detail! Everything is looking great!
Old Jan 24, 2018 | 07:59 AM
  #40
ILuvJDM's Avatar
Finally got the truck down on 4 tires for the first time in months. I was worried it wouldn't get low enough with the springs I had, but it's at 14.25" hub to fender and actually tucking tire. I need to raise it up, but this was just a temporary bolt in of them to make sure they would work.
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-ozi7txc.jpg
I also need to figure out why my heim tie rod ends are so far out of range. Is there a difference between lengths of the inner tie rods between rack and pinion and recirculating ball steerings? I had these made for my torsion bar truck and they worked great, but these barely catch a few threads when adjusting the toe out. You can see how much toe in is in the picture, that's where the tie rod ends feel safe to me with thread engagement. Anything further and I feel like its a death trap...
Steering wheel is straight ahead in this picture:
ILuvJDM's 2007 NBS RCSB Build - Turbo/4L80e/Coilovers/Wilwoods-gkktobm.jpg
