I hope I'm not late for work!
Old Jun 24, 2015 | 10:15 AM
  #861
Atomic's Avatar
I have a gauge for that
Yea thats pretty much what mine will look like, but with connections at the front. Spray bars fogger same thing.
I had to fix up the harness but the bolted right in. I had power and ground to my inverter right there so I just tapped into that.
Old Jun 26, 2015 | 10:44 AM
  #862
Atomic's Avatar
So I got to mess with getting all the coolers and junk to fit up front, not going to be easy since I am putting the AC condensor back in and have a separate oil cooler. Stuff that needs to fit up there: Radiator, AC Condensor, Oil Cooler, Trans Cooler, SC Heat Exchanger. I made a couple cross bars that I can bolt stuff to, problem is the trans cooler is just too big so I ordered a smaller one (11x13) instead of trying to use the giant trucool. This way it will be radiator, condensor, then trans cooler and oil cooler beside each other, then SC hex in front of that.
Old Jun 26, 2015 | 11:03 AM
  #863
sprayedenali's Avatar
put the oil cooler and trans cooler under the truck with their own fans
Old Jun 26, 2015 | 11:26 AM
  #864
Atomic's Avatar
I tried that before with my other truck and they worked horribly, so I would really rather keep them in the direct airflow path.
Old Jun 26, 2015 | 11:42 AM
  #865
Really..? thats how mine are and it works great!!! whatd you do wrong?!? haha
Old Jun 27, 2015 | 01:51 AM
  #866
Blown06's Avatar
8 Second Truck Club
I run my trans cooler under the truck without a fan and it does fine.
Old Jun 29, 2015 | 07:30 PM
  #867
BlackGMC's Avatar
Resident Retard
My RDS spacer came in today. I am not sure if you machined the bolts holes for orings or not. The RDS space came with a bunch of little orings to go around the bolt holes.
Old Jun 29, 2015 | 09:35 PM
  #868
Atomic's Avatar
That seems a little unnecessary considering the main oring is interior of the bolts...
Old Jun 29, 2015 | 10:18 PM
  #869
BlackGMC's Avatar
Resident Retard
on mine the bolts are on the inside. So i think those areas would see vac/boost. YES/NO?
Old Jun 29, 2015 | 11:49 PM
  #870
Vortec350ss's Avatar
I would think so too. Lookin good!
