I hope I'm not late for work!
Old Aug 12, 2015 | 01:14 PM
  #961
03sierraslt's Avatar
Originally Posted by kbracing96
Make SURE you put anti-seize on the IW balancer. I was supposed to get one with the KB blower I bought, but the guy could not get it off the crank. He had to pull the motor, take the pulley apart and cut the hub off the crank, destroying it. They corrode to the crank and you can't get them off.
What kinda bullshit is that.
Old Aug 12, 2015 | 01:52 PM
  #962
Vortec350ss's Avatar
whoa... i hope I dont have the same issues.
Old Aug 12, 2015 | 02:03 PM
  #963
Atomic's Avatar
I have a gauge for that
I put a lot of heavy oil/grease on it when I installed it...I wonder if that will suffice...
Corey, yea that is what I tried to use. The remove tool tore off the lip of the pulley without budging on the shaft. I tried a 3 jaw puller on the pulley itself and it only bent the edges of the pulley and wasn't budging either.
Old Aug 12, 2015 | 06:48 PM
  #964
Hulign's Avatar
This just put a halt on my parts ordering...lol. I already bought the IW pulleys. Let us know what you get figured out!
Old Aug 12, 2015 | 06:59 PM
  #965
BlackGMC's Avatar
Resident Retard
OH, man that is insane!
Old Aug 12, 2015 | 07:01 PM
  #966
Atomic's Avatar
So I got the 100mm metco idlers...I really just need the one on the right since I could make the IW one work for the one on the left. It looks like it may be too big of a diameter to clear the waterpump and alternator bolt, and I need to make a spacer for it...
Working with Mike at whipple to see what is going on with the blower pulley...
Old Aug 12, 2015 | 07:03 PM
  #967
BlackGMC's Avatar
Resident Retard
YEah i can't adjust one of my idlers all the way down because it hits the Water Pump pump. So i lost the maximum adjustment but just slightly using those pulleys...
Old Aug 12, 2015 | 07:10 PM
  #968
Atomic's Avatar
You got the 100s, right? That alternator bolt is going to be close...
Does the maggie bracket have a built in step to support the idler like the whipple?
Old Aug 12, 2015 | 07:19 PM
  #969
BlackGMC's Avatar
Resident Retard
yes i got 100s, yes one of them had a step.
I can take it apart Friday and snap you some pics if you want.
Old Aug 12, 2015 | 07:20 PM
  #970
BlackGMC's Avatar
Resident Retard
also if you want some measurements of anything let me know.
