I hope I'm not late for work!
Old Jun 9, 2015 | 09:08 AM
  #791
Vortec350ss's Avatar
So the fuel rails will mount below the spacer? Will you notch it to make them fit i assume?
Old Jun 9, 2015 | 09:11 AM
  #792
sprayedenali's Avatar
port that lower!!!!!
Old Jun 9, 2015 | 09:48 AM
  #793
walledition's Avatar
you my friend are my HERO!! thats one badass first date, i guees that was a test to see if she was a keeper or not? lol good one
Originally Posted by Atomic
Nah, wont do that until after the wedding. This one has sentimental value that we want to drive away in it from the wedding. Our first date was her watching me pull a transmission out. Figured it was a good way right off the bat to see if she would squawk at the truck hobby
Old Jun 9, 2015 | 10:02 AM
  #794
Atomic's Avatar
I have a gauge for that
The fuel rails mount on the lower manifold only (see the picture above). The spacer is a perfect match to the upper manifold, so it would be an extension of the upper manifold downward, so no need for clearancing anything. Just need longer bolts to hold the halves together.
And Mitch, the lower is ported, believe it or not!
Old Jun 9, 2015 | 10:25 AM
  #795
ChevyThunder17's Avatar
Have you seen the issue regarding the fuel rail bolts that I spoke of? They were pretty miserable to install/remove. Or did you find a workaround?
Old Jun 9, 2015 | 10:32 AM
  #796
Atomic's Avatar
Yea I'm not really looking forward to that part honestly
Cant decide if it would be easier to install the lower manifold first then attach the top, or assemble the whole on the bench and install at once. Either way getting under the intake thing is going to suck. I did buy some skinny bit adapters and have a swivel fitting I am hoping will make it easier.
Old Jun 9, 2015 | 12:08 PM
  #797
1FastBrick's Avatar
Custm2500's Rude Friend
Make your spacer yet?
I wanna see this thing go already.
Old Jun 9, 2015 | 12:45 PM
  #798
Atomic's Avatar
Spacer should be done by the end of the week...weekend is busy, but maybe I will get time next week to mess with it. I posted a solidworks rendering of it above if you missed it.
I have all the parts I need to reinstall AC, just need the time. Need to relocate my oil cooler as its on the same plane as the condensor. I figured out what I needed to do with the steam vent things, just need to run new hose. Had to trim the accessory bracket a little but no big deal.
I am going to install the 8 rib crank pulley I have but still use the 6 rib system in the mean time until I get everything going.
I still want to pull the current cam and install my new one along with change out the heads, just need time
Old Jun 9, 2015 | 02:06 PM
  #799
afternoon's work!!!!
Old Jun 9, 2015 | 02:35 PM
  #800
GMCtrk's Avatar
AC is critical....eventhough I rarely use it, it's nice having it when I want to roll the windows up and go.
What's the fastest 1/8 mile time this truck ran turbo'd? Did you ever run it in the 1/4?
